1995 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Super Exceed model, Metallic dark blue color with Grey color tone on it, L400, has 160,000 kms.
this car is clean & seen no Rust as you can see the chassis under carriage.
This L400 has dual Battery & its has a Winter Package on it;
Automatic, crystal lite roof, A/C, 7 passenger, 134A AC, fully loaded, will do full compliance
Will install New original Mitsubishi headlight E-Code, and full service for this newly designed L400 Delica
New Tire, Radiator, Water Pump, thermosthat, Belt, air filter, fuel, all fluids change , new 4 shocks pro comp 9000 series
Check all brakes, Delica L400 tune,new coolant, check stabilzer bushing if need change, replace water bottle anti freeze, if broken or seen any sign of cracks. this delica is clean.
will Include a 1 yr or 12,000 kms Powertrain Warrantty whichever come first:
Grade 3.5 & B
SOLD
Stock # PE8W
Any questions please call me:
604-247-2111 / 604-720-6144
thanks,
95 Delica L400 SPACEGEAR Diesel 160k Auto *SOLD*
- MardyDelica
- DSCN1148.JPG (85.45 KiB) Viewed 4009 times
- DSCN1132.JPG (86.78 KiB) Viewed 4011 times
- DSCN1134.JPG (87.4 KiB) Viewed 4008 times
- DSCN1141.JPG (84.23 KiB) Viewed 4008 times
- DSCN1146.JPG (69.82 KiB) Viewed 4006 times
- DSCN1147.JPG (82.75 KiB) Viewed 4002 times
- MardyDelica
Re: 95 Delica L400 SPACEGEAR Diesel 160k Auto SOLD
More Pictures;
- DSCN1160.JPG (84.38 KiB) Viewed 3984 times
- DSCN1159.JPG (89.86 KiB) Viewed 3983 times
- DSCN1156.JPG (77.03 KiB) Viewed 3977 times
- DSCN1155.JPG (60.07 KiB) Viewed 3976 times
- DSCN1152.JPG (72.5 KiB) Viewed 3975 times
- DSCN1150.JPG (79.52 KiB) Viewed 3974 times
- MardyDelica
More pictures:
- DSCN1169.JPG (87.39 KiB) Viewed 3958 times
- DSCN1168.JPG (86.83 KiB) Viewed 3952 times
- DSCN1165.JPG (69.9 KiB) Viewed 3952 times
- DSCN1162.JPG (76.61 KiB) Viewed 3948 times
- DSCN1163.JPG (72.3 KiB) Viewed 3941 times
- MardyDelica
Re: 95 Delica L400 SPACEGEAR Diesel 160k Auto $10,800 in Transit
Update: This Delica L400 Super Exceed will be here next month In transit now:
Cheers;
Cheers;
- MardyDelica
Re: 95 Delica L400 SPACEGEAR Diesel 160k Auto ON HOLD Arrived
Hi, this Delica L400 is on Hold now
Thank you
Thank you
- mdrive
mardy, you need to call me asap.
- MardyDelica
