Hello,
I am looking for front brake pads. Can I purchase them at local auto part stores? ie; Lordco.
Also, do I need specific cross reference numbers?
Local Part Suppliers - Burnaby
meteorworks
- Vehicle: Mitsubishi Delica
- Vehicle: -
Re: Local Part Suppliers - Burnaby
Welcome!meteorworks wrote:Hello,
You can get brake pads at auto part stores for a Mitsubishi Montero '88 which will fit.
If you use the search, you will find tons of information on that subject.
- loki
fexlboi wrote:Welcome!meteorworks wrote:Hello,
that is if you have an L300, your post nor profile specify if your have an L400 or L300, they both use Montero pads but different years. again with a little use of the search here or google search with site:delica.ca added will bring up posts that have the NA part numbers.
By the way, where are you located? It helps when telling you where to find something.
