1993 Mitsubishi Delica P35W Super Exceed For Sale
Nomis
Vehicle: 1993 Super Exceed
Post by Nomis »
Hi,
I have been a long time reader of these Forums.
I bought my rig from Mardy 2 years ago to this month.
I'm a newbie at selling a vehicle, so all I can say is that it's a sweet ride and has no problems.
It's treated me well, but time to move on.
Here's the detailed info:
1993 Mitsubishi Delica P35W Super Exceed, Green & Gold, 104,400Kms, 4WD, LSD
- High Roof w/ Crystal lite windows
- Roof Rack w/ Basket & Box, ladder on back (see photo minus front lights)
- Dark Tinted Windows
- Sliding side & rear windows
- 7 Seater, Mid Captains Chairs, 360 swivel, Bench seat in back
- Convertible Bed & Storage Box in place of bench seat, (comes with both or either, see photo)
- Yokohama Geolander Tires ATS (2year wear)
- dual battery & block heater with plug for cold weather
- CD player with mp3 device plug in
- Imported in 2008, driven 2 years, full BC certification, no problems
$10,900 (no tax)
work done by CVI Automotive in Richmond BC, when imported in March 2008
(Full Mardy "Deli-Tune")
- Timing Belt Change, 71,820Kms
- Replace new outer tie-rod end
- Fuel & air filter change
- New Front Brake Pads
- 4 new shocks with new rubber booth cover
- Trans. Filter change & Reseal
- Replace Middle Transfer case, Front & Rear diff gear oil
- Install B/new Depo Headlight E-code mark and daytime light & modification
- New Water Pump
- New Polyutherane Bushing from sway (upper & lower)
- Change 4 seal(Camshaft, crankshaft, oil pump & Tensioner seal) (Mitsubishi Org.)
- Front Wheel Alignment & adjust torsion bar
- re-pack front axle & Machine front rotor & rear brake drum
- Change tensioner bearing 2pcs Brand new GMB brand
- New Fan belt 4pcs New
- New front & rear windshield wiper Blade, flex type blade
- New valve coer gasket & adjust valve tappet
- align & aim headlight with inferred headlight aimer
- New front & rear reflectors
- re-grease all cross joint fitting front & rear
- Clean EGR valve
- Reseal inside & outside front panel for floor leak
- new thermostat
- lower radiator heater
- 4 new fan belts (Japan Made)
contact Simon for view or sale info @ 604-886-4193 or reply by email.
located in Gibsons on Sunshine Coast, BC.
full frontal, without roof rack
comes with roof rack basked & box, minus front light rack as seen in photo. (rack is currently dismounted)
convertible bed/storage box, bench seat still available as well
bed extended over captains chairs.
chairs upright
chairs upright
ladder on back end
ladder on back end
nicbazin
Re: 1993 Mitsubishi Delica P35W Super Exceed For Sale
Post by nicbazin »
Hello any chance I can have a look at it?
Thanks Nic
nicbazin@gmail.com
