Built by Noel at Enviroimports in Spring 2009.
It has an lockable tire-carrier for up to a 30" tire (maybe 31"), an area to store 4 Scepter fuel cans and a secure compartment with a door on each side in the front as an air deflector. Also there are two heavy-duty rubber clamps to tie down a shovel on one side.
This rack is exactly designed for a Delica l300 with high-roof. All three crossbars have different heights to accommodate the angel of the roof for minimum space between roof and rack. It is designed in a way so it does not block the crystal-light windows.
The basket is out of aluminum and the crossbars are black-coated metal to give it a very strong base. All hardware is stainless steel.
Another great feature are the extendable awning poles, which are stored on the side. They just slide in some mounting holes and can be used with a tarp to cover the whole side of the van. Many tarp setups are possible.
We used it on our trip to Inuvik and a few other road trips and it is absolute handy. If our new van would not have 32" tires, we would keep it for sure, but unfortunately the spare tire does not fit.
For Sale: Custom Roof Rack for l300 high-roof - SOLD
- Vehicle: -
- 008.jpg (124.4 KiB) Viewed 5440 times
- 007.jpg (115.94 KiB) Viewed 5444 times
- 006.jpg (144.4 KiB) Viewed 5437 times
- 01.jpg (160.92 KiB) Viewed 5459 times
- 004.jpg (113.45 KiB) Viewed 5431 times
- 002.jpg (60.6 KiB) Viewed 5428 times
- 001b.jpg (93.32 KiB) Viewed 5436 times
- Vehicle: -
Re: For Sale: Custom Roof Rack for l300 high-roof
Here is the drawing on which the rack is based on.
- 001a.gif (36.47 KiB) Viewed 5395 times
- after oil
hi.
im interested. how much does it weigh? ill be away all day so ill correspond this evening
thanks
for some reason i cant PM this morning
thanks
- Vehicle: -
Not sure, but it can be easily lifted from one person. You need three people to mount it if you don't want to scratch your roof though :)after oil wrote:how much does it weigh?
( Also there are two heavy-duty rubber clamps to tie down a shovel on one side.)
Those rubber clamps look like what I need to carry my paddles. Where can you get them?
Larry
Larry
- Vehicle: -
http://www.endroad.comlrp374 wrote:Where can you get them?
bikepoor
- Vehicle: 92 Delica Exceed
All looks great, will fit, can schedule a trip, does it come with the tarp?, and biggest question, how much?
Bikepoor
(in Calgary)
Bikepoor
(in Calgary)
- Vehicle: -
Re: For Sale: Custom Roof Rack for l300 high-roof - SOLD
The roof rack is sold.
Schwartz's Deli
- Vehicle: 92.5 White P-35 Exceed
Damned rights it is...fexlboi wrote:The roof rack is sold.
