Big Blue has been very good to me, and I hate to see her go, but with a baby coming in a few weeks, I've got to get some mortgage money for when I'm on parental leave. She doesn't get driven as much as I'd like anyway, as my other '91 Delica has been my daily driver.
If you are looking for a clean van with a reliable record in Calgary winters and no surprises, check it out.
I'm asking $9,500. Here's the details:
• 1990 Mitsubishi Delica Exceed (P35W) High roof model
• 2477cc turbo diesel (4D56), automatic transmission w/ overdrive, 4WD
• 61,xxx km
• 7 seater with captain’s chairs
• Power locks and windows
• Blue over white with blue-grey interior
• Rear windows have light bronze tint
• Dual zone A/C (working)
• Original floor mats included, as well as custom cut mats to tailgate
• Pyrometer
• Factory tool kit
• Goodyear Wrangler 235/75 R15 – almost new
• New 750 CCA Spiral core battery February 2009
• Glow plugs on manual (Wilson) switch
• Temro inline coolant heater and Polar Pad oil pan heater
• Under-seal and paint protection from Shine Factory
• Colour-matched Line-X on roof, and black Line-X on bullbars, steps, bumper, and underplating.
• Sony Radio/TV/CD (Japan frequency band) with Sony 10 disc changer, compatible with mp3 players.
• E-code headlights
• Rear Curtains
• Interior is excellent, clean with no wear/tears in seats, non-smoking vehicle
• Front quarter panels sealed (no wet floors) as well as oversensitive horn fixed
• 57 point inspection from Kirkham Auto is available for review, a reputable NAPA/AutoPro shop with Delica experience
• Well maintained and very reliable, purchased from Luxury Imports 4 years ago
• Includes NEW maintenance and service parts:
- Oil, fuel and air filters (1 each)
- Upper and lower rad hoses
- Timing and balancer belts, with tensioners
- Water pump
- Thermostat
- Oil seal gasket
• Work completed within last 1000 km:
- Front and rear diffs serviced (synthetic gear oil)
- Transmission flushed and serviced
- Front hub bearings and seals replaced
- Front brakes relined
- Stabilizer sway bar bushings replaced
- Torsion bar adjustment with wheel alignment
• Work required:
- Timing belt change - all required parts plus recommended maintenance parts are included as above
- Oil seepage from the back of the valve cover/turbo area - valve cover gasket on order and included in deal
- ATF leak between transmission and transfer case - gasket on order and included in deal - estimate from Kirkham Auto is about 3 hours labour ($330)
