l300 petrol with no spark
abbot
Vehicle: mitsubishi L300
Post by abbot »
i got a l300 and just put a new head on it but now have no spark any ideas anyone ???
Golf Cart
Vehicle: 1992 Exceed
Re: l300 petrol with no spark
Post by Golf Cart »
abbot wrote:i got a l300 and just put a new head on it but now have no spark any ideas anyone ???
yup, lots. :-)
But it would be easier if you told us what you have checked so somebody here could tell you what you haven't.
Not many Benzene burners here, mostly diesel. So in your case you'd trace where the power to the plugs stops. Plug wires, coil wire , coil packs, getting power to the distributor, alternator, battery, timing. How did you test if you have spark. Just to name a few. You might want to PM Josh or Doc Savage, as I think they both are Gassers. The engine may be different , but the process is exactly the same as any other 4 cylinder gas engine.
Good Luck
rlsimpso
Vehicle: 89 Mitsu Van/Wagon LS X2
Post by rlsimpso »
I have a gasser. I have not had any spark issues though, so all I can give are some suggestions.
As mentioned above, check wires, cap, rotor, plugs, fuses, etc.
The label on the fan shroud indicates plugs should be replaced every 70K miles/100 Kilometers. Have you changed them? I found the cheap plugs made mine very unhappy. Replaced the cheap ones with proper NGKs and have no problem since. I did the wires, rotor, and cap at the same time.
How have you confirmed you have no spark?
This is my current favorite tool to testing spark at the moment: http://www.amazon.com/gp/product/B0002S ... Z6HB72CGFA
The Lisle site is down as I am writing this, or I would send a direct link to them.
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
Did it have spark before you pulled the Head?
If so: I would check all connectors and the GROUNDS.
Next I would find the diagnostics for the motor (maybe in another vehicle and follow it).
Be systematic and it will show up...good luck
