flourescent ballast replacement?
- torchard
- Vehicle: 91 Exceed
Has anyone replaced their overhead light ballast? If so, any specs, sources? I'm not certain but I think it might be the nub of my problem which is very dim light. I replaced the orginal tube less than a year ago, so I'm thinking the bulb is not the culprit. It seems susceptible to the cold (if you can call Victoria weather cold at any time). Thoughts? Thanks. --todd
'91 Exceed
Nimbus 2000
Nimbus 2000
- Mr. Flibble
Re: flourescent ballast replacement?
I have never replaced a ballast in a vehicle. However, this link which is generic for ballasts might help:
http://www.standardpro.com/product/cate ... .aspx?id=2
