Sold
Re: L300 - Toyota alloy 15" rims for sale
I'm assuming these would fit an L400 as well? or is there some reason I wouldn't want to do that?
They won't fit on an L400.
Center bore is 2mm larger on the L400 than the L300.
- DeliTan
Is the bolt pattern the same? Could the holes be "opened up"?jfarsang wrote:They won't fit on an L400.
john
Most Toyota rims have a center bore of 106mm
Mitsubishi L400's , 2nd Gen Pajero's have a hub diameter of 108mm which means you'd need to hone out the center bore hole 2mm on the Toyo rims.
L300 delica's and 1st gen Pajero/Montero's have a center hub size of 106mm which fits the Toyo's perfectly.
too bad, I really need some rims for my second set of tires...
