93 Delica exceed Auto,67k, low roof grade 3&B *SOLD*
MardyDelica
Post by MardyDelica »
1993 Mitsubishi Delica L300 'Exceed' Edition very low mileage No rust
Grade 3 & B
2.5L turbo Diesel, 4D56T engine, 4x4, 67Km. Automatic, Low roof, A/C. 7 passenger, fully loaded
This is a newer engine water cooled. much better than old 4d56 engine without any water cool.
it has a newer version of glow plug ECU, compare to the old design Glow plug ECU which has now mainly the common problem for the glow plug ECU as usually the ECU break all the time.
this has the upgraded version glow plug ecu which is very good & more reliable.
Recent work :
LED day time running light , so no more of having problem with the headlight switch. more reliable.
Full Tune up
New Timing belt
Belts
Water pump
New thermosthat
New radiator 4 core, not recore
New tires
New engine seals, Crankshaft, camsahft, oil pump & balance shaft seal all new
Delica-tune= Clean injector
Good brakes
Front hubs repacked
All fluids have been changed
New Fuel filter
New valve cover gasket
New transmission filter & fluid
Rear end new gear oil
Change All front stabilizer bushing
Adjust intake & exhaust valve
Crome bullbar like super exceed model
Start and runs very strong.
Depo LHD headlights with E-Code on it
Stock no. P25W-
Pls call me if need to view the vehicle ready to go:
604-247-2111é 604-720-6144
Cheers:
MardyDelica
Re: 93 Delica exceed Auto,67k, low roof $8,500 On Sale
this L300 is on Sale now:
its direct from japan ready to go never been used here in canada
Cheers;
MardyDelica
Re: 93 Delica exceed Auto,67k, low roof On HOLD grade 3&B
Update:
This Delica L300 is on HOLD now
Thank you
Paule
Vehicle: 1997 L300 Active World
Post by Paule »
Awww...
I was using the Force trying to get this one to stay available for about another month so I would have the $$.
I guess I'm not much of a Jedi.
MardyDelica
this Delica L300 is SOLD:
Hi, Paule,
i do have one coming next month.
pls phone me if need one:
thank you
