   O.K I have looked through a WHOLE BUNCH of posts on this and lots of possible answers so...
 O.K I have looked through a WHOLE BUNCH of posts on this and lots of possible answers so...1- 1992 Delica Exceed, 33,045km. Rad flush, timing belts done fluids changed, Living in Saskatchewan and don't have the finances to visit CVI or CC auto.
 No work done recently to motor or fuel system. Van Fell on its face, poor idle, blue/black smoke out exhaust till warmed up.Talked with Firesong and got new filter and water bleed out O-ring from him (THANK-YOU!) Installed and bled air out of filter and still have  Black smoke on startup and stumbling idle, but the stumbling idle will clear up.
  No work done recently to motor or fuel system. Van Fell on its face, poor idle, blue/black smoke out exhaust till warmed up.Talked with Firesong and got new filter and water bleed out O-ring from him (THANK-YOU!) Installed and bled air out of filter and still have  Black smoke on startup and stumbling idle, but the stumbling idle will clear up.Power will also be intermittent, Lots of pull one minute then gutless the next.
Fuel filter was original??? Dark green/black in colour with no writing on it at all. Fuel lines held on with banjo clamps.
Timing belt was installed by the shop who imported the Deli for me. The do not specialize in diesels.
-Have many members had problems with degraded fuel lines letting air into system? would this cause intermittent power loss?
-can the Injectors clog then clear, or is this a clogged and thats it kind of situation?
-Once air is in fuel system will it trap at the filter or can it pull through?
Thanks for your time,
Eric
 ....  Unless it was sitting in Yokohama, or somewhere, for a long time and the seals dried out, in which case a new timing belt might be a good idea.
   as I am not a mechanic by trade.
