I was exchanging with original 6 CDs stereo (6CD box was removed when it arrives here) with aftermarket stereos to get full AM/FM range here.
When I remove the stereo, I have noticed there's two plugs, big one is antenna plug but small one is... Do anybody know what is it?
Radio/Stereo swap
- Spade J
- Vehicle: 94 L400 SuperExeed SWB
Radio/Stereo swap
Spadelica
94 L400 Super Exceed
Spadelica
- loki
Re: Radio/Stereo swap
pictures are so helpful in situations like thisSpade J wrote:I was exchanging with original 6 CDs stereo (6CD box was removed when it arrives here) with aftermarket stereos to get full AM/FM range here.
- Spade J
Here the picture below, the big one is antenna plug.
- IMG00038-20091229-1040.jpg (19.09 KiB) Viewed 3299 times
Spadelica
Spadelica
Could be a television input or a satellite input...
big plug is the retractable antenna on the driver's "A" pillar, small antenna is the antenna built in to the glass on the rear passenger corner of the vehicle.
Your new stereo will likely only have the one plug, so you'll loose the second antenna, not really a big deal.
