I have a 93 Pajero. The valve stem was broken when I had snow tires put on. It does not fit a schrader.
Where can I get a new rim that fits schrader?
Where can I get a japanese valve stem?
Is it possible to get a new hole machined on my existing rim - to fit schrader.
I live in squamish. the major tire stores cannot help eg. kal tire
Help. I am running with no spare and it's our family vehicle.
Ron
Pajero rim and valve stem problem
Ron Pajero
- Vehicle: Pajero
- Jungle Jon
- Vehicle: Toyota Tacoma
Re: Pajero rim and valve stem problem
Hi Ron,
I had the same thing happen to me... the day before a road trip.
I'm guessing you may have the same oddball 6 mm valve stem that I have, I found some replacements at 1010 tires: Here
Kal tire was good enough to set me up with some rims for my trip, and then took the rims back and swapped the tires back for free when I got the replacement valve stem.
Good luck.
Good luck.
- MardyDelica
hi, ron, try volco they may have soem specialty valve stem.
i buy from them as they have most of the aftermarket rims
cheers;
cheers;
