As the subject line says ...
Could someone give a description of how this operates and-or what might be wrong: The controls all seems to be working properly e.g. the fan runs fine, the vents adjust properly, but it blows only ambient air.
As I understand it, there are inlet/outlet lines from the manifold running back and up through the floor to this heater/fan/air con unit with apparently no valve or anything inline, correct?
So I'm assuming the control valve that opens/closes allowing hot water to the heater core and related linkage is located inside the van under the rear control panel and accessed from w/n the van, - is this correct?
My thinking is that whatever is wrong would likely be found under the rear panel, correct?
Anybody got pix?
--T
no rear heat: how is this plumbed?
- torchard
- Vehicle: 91 Exceed
docsavage
- Vehicle: Deliless...
- torchard
