Konnichiwa wrote:jfarsang wrote:I don't know what you are looking for.
Please ignore all of my previous threads and posts in this entire forum over the past few years.
Call ICBC or CVSE.
I'm offended and done with this discussion.
LOL. I should be the one who's offended... but I'm not.
If you make a claim, you should be able to prompty back it up with facts (reference).
HINT: Section 5 has important information ;) ;)
Ad nauseum, ad hominem and hearsay doesn't work with me.
I did back up my 'claim' with a 'reference'.
A direct email " quote " from Brian Kangas.
Read above, in past posts and below AGAIN !
jfarsang wrote:From Brian Kangas, the technical advisor ICBC :
"Tires need to indicate clearly that they meet CMVSS standards. Inspectors
and enforcement need to be able to identify the tires are safe. Load
ratings and PSI are specifically what needs to be identified. DOT indicates
clearly that the standard is met. Some E codes will have the markings as
well. If there is no way to determine the compliance, acceptable documents
certifying that the particular tire does meet CMVSS need to be provided,
similar to what happened with the JIS lenses.
The JIS marking alone is not a clear indication of the safety information.
Hope this is helpful
Brian"
Email or call Brian directly to get the same email I received above.
If you speak to him like you word your posts on this forum, be prepared to be hung up on via phone and not replied to via email.  He does not tolerate disinformation nor repetitiveness.
He is a good guy and has made enormous amounts of headway with IVOAC and the importation of JDM and 'other' country manufactured vehicles.
All of the information I listed, he will point you towards and please note that your questions have been answered YEARS AGO.
brian.kangas@ gov.bc.ca
This is the last post I will share with you.  I don't even know who you are and I'm treating you with more respect that I normally do considering your other slandering posts.
