Injection pump
				asorensen
Injection pump
I have just redone the seals in the Injection Pump ( yay no more leaky pump!).
I replaced the main seal from the top half of the pump, the o-ring from the throttle linkage and the copper washers from all of the banjo bolts.
This is a fairly easy procedure and there is a post somewhere with pictures on the UK site maybe.
The leaks were coming from the main seal and it was quite visibly folded when I removed it. I had a rebuild kit sent up to me from Action Injection in Naniamo(250.758.3221) Be sure to have you pump type and number when you call (Mine is Desiel Kiki Pump No 104640-8220). It cost $15.85 after tax.
Hope this may help someone.
Andy
Andy
- MardyDelica
				trilobyte650
				trilobyte650
Just had a quick look.  I see a number on a sticker (easily visible) and what looks like a stamped number under the throttle linkage (need to remove linkage to see it clearly).
I've read the post on the UK site but it's still not entirely clear to me how to proceed. Did you just start disassembling from the top down while the pump was still in the van? Does the pump actually have to be removed to get at the main seal (which seems to be the culprit in most cases)?
Peter.
Peter.
				asorensen
I have tried to find the picture version of these instructions but for the life of me I cannot.
These instructions here a pretty good though:
http://www.pocuk.com/forums/viewtopic.php?t=11498
The number should be the one stamped on the pump around the area of the AC Idle up diaphram.
In response to mardydelica I can't say for sure but it seems from what I have read and my own experience that the top seal is epecially suseptible to leaking based on the old design. Mine was visibly folded in several locations. For this reason I felt somewhat confident that this fix, which I was capable of, would be an economic and hopefully long term fix for this problem. If not I have wasted $15.85 and a couple hours!
Andy
Andy
- MardyDelica
Hi, Andy,
I know you want the job to make easier & cheaper, but to tell you on my own experience its just a waste of time to change just the top part. my mechanic did it before but ended up to do the whole thing cause other part of the pump seal leak. so i have to re do it again. just a waste of time for me thru my experience. when you do it all change the seal ,o-ring & other you can guarantee for sure 100% its wont leak & last longer you wont waste your precious time.
Hope this help
Hope this help
				trilobyte650
				Krackie
- Location: Victoria, Tofino and Ucluelet, British Columbia, Canada
Re: Injection pump
I am having the same dilemma.  Fuel is leaking, either put in a rebuild pump for about $1400.00 of go for changing a gasket and see what happens??  Anyone else have recommendations?
Re: Injection pump
1400 ?!?!  where are getting it done ? NASA ?
Ignition pump complete rebuild/gaskets/rings should be in the $500-600 vacinity.
				Krackie
Re: Injection pump
you mentioned [i]ignition [/i]pump - I am referring to the [i]fuel/injector pump unit[/i].  are we talking about the same thing?
The quote from Glenn at CCC was anywhere from $900-$1300 for the rebuild (depending on the condition of the pump)plus 4-5 hours labor.
Re: Injection pump
Injection pump
I guess it would vary from place to place (labour rate) and what needs to be replaced.
+1k seems excessive
+1k seems excessive
- Hankster
- Vehicle: 92 P-25 MyPod
				asorensen
Re: Injection pump
I guess that original post is more than a year old now. My pump is not leaking, so far so good!  You do have to realize that this is a very sensitive part of your vehicle.  You do not want foriegn object getting into you pump so if you do attempt this be very careful.   I imagine that for some people $1000.00 is peace of mind in the sense that their is no risk involved but hey I am living on the edge and a cheap bastard to boot.  I however accept no responsibilty if you wreck your vehicle!
Andy
						Andy
				asorensen
Re: Injection pump
Just passed the two year anniversary of this fix.  Holding up well!
Cheerio
Andy
						Cheerio
Andy
				josh
- Vehicle: L300 poptop gasser
Re: Injection pump
Andy,
I'd say that was the best $15.85 you ever invested into your van hey? I would say thats as good of a result as you could ever expect. I love the yearly update... I look forward to next years and the years after! (say about 15 more years till the next change? or is that to much optimism? *grin*)
Josh
Josh
