Introducing....CVI's Glow plugs ECU fix!
We have this service available now where we can do a preventive maintenance fix on damaged ECU's or upcoming problems with the ECU not cycling properly. This problem will be much more noticeable this coming winter when temperatures get colder. Service includes removal and installation and replacement of all possible parts inside the ECU which are about to malfunction. Price is tagged at $100.
CVI's ECU Fix (Delica Glo plug ECU)
- CVI
- ECU DELICA (3).jpg (93.81 KiB) Viewed 2576 times
- Body File
- Vehicle: 93 Jasper
Re: CVI's ECU Fix (Delica Glo plug ECU)
Well worth it.
I got it done and couldn't believe the difference it made to starting and idling
-Dave
-Dave
Bluestreak (industry leader for ECU repairs) charges $70 to repair them ( they are all the same ... The vehicle make doesn't matter) but you have to send it in and they take usually two weeks to get it back.
So for a hundred including removal and installation is a good price.
