Meager Creek HS access as of Sep 22, 2009 - updated
Profister
Post by Profister »
Vehicle: -
Re: Meager Creek HS access as of Sep 22, 2009
Post by fexlboi »
Well, I would say no Meager Creek hot springs for a little while :)
patty
Vehicle: delica chamonix
Post by patty »
looks like i got out of there at the right time. as of 3 weeks ago i was spending my days drivin just up the road from this slide! hope mikes work on the hotsprings isnt undone.
Profister
Post by Profister »
Tobogganing hill come snowfall 8-)
Profister
Re: Meager Creek HS access as of Sep 22, 2009 - updated
Post by Profister »
Update from Grig: the mud slide is still not passable even on foot (soaking wet) and it looks like nothing can be done about it for a while. :-(
You can always go around from the back I believe.
Vehicle: -
Post by fexlboi »
jfarsang wrote:You can always go around from the back I believe.
To Meager Creek? That's new to me. How would you go?
I think you mixed it up with the Harrison Lake slide/hot spring.
Profister
Post by Profister »
I have never heard about a reasonable way around but my point was to give you an update only. 8-)
gtexjunkie
Post by gtexjunkie »
The hot springs are closed for the remainder of the season, mainly to reduce the incentive for people to try to make their way through the mud, rocks and debris, Greinacher said. He said the mud is waist-deep in some areas and some of the large boulders that came down with the slide could shift and injure someone.
The remainder of the area, however, is still technically open, though officials are not recommending travel via the Meager Creek route.
“It is hunting season, and there’s access to the Harrison Hut at the Overseer Glacier. You could always go in through the Elaho and go back the way you came in,” Greinacher said.
