94 Delica exceed Auto,56k, * Arrived SOLD *
MardyDelica
Post by MardyDelica »
Hi, have one nice 1994 delica exceed with Low mileage 56k, nice condition, it has winter package, include full service , new tire, radiator, change timing belt & water pump,shocks. 1 yr warrantty or 12,000 kms which ever comes first included & other services. in transit ,very rare to find a nice color & 94 model now a days with this such a low mileage.
this has a water cooled turbo engine.
Stock # P25W-6830
pls call for details: 604-247-2111 / 604-720-6144
Cheers;
P25W 59k.jpg (61.6 KiB) Viewed 7957 times
P25W 59k1.jpg (57.93 KiB) Viewed 7958 times
P25W 1.jpg (65.27 KiB) Viewed 7956 times
MardyDelica
Re: 94 Delica exceed Auto,56k, * In transit *
Hi, this delica is on Hold,
recieved Deposit;
Thank you
Mephisto
Vehicle: 90 5spDelica, 93 2.8 5speed SWB Paj
Post by Mephisto »
Is that a factory water cooled turbo, or is that aftermarket?? I haven't heard of any of these coming with water cooled turbos, just wondering if that was an option.
MardyDelica
hi, its a factory water cooled turbo. this is updated newer design for this 4D56 engine. not aftermarket. origianl & tested.
cheers;
Mephisto
Post by Mephisto »
To clarify, all delicas have water cooled engines, a water cooled turbo has both an oil feed and a coolant feed line to the turbo, this helps keep the turbo temperatures in check as well as helping to minimize the carbon build up from burnt oil on the bearings after a hot shut down. Which of these things are you referring to; a water cooled engine, or a water cooled turbo?
MardyDelica
hi, this will be a water cooled turbo. for the newer one.
it has water temp sensor attached thru injection pump.
Cheers;
Mephisto
Post by Mephisto »
So that would cause me to assume that all the 4M40s have water cooled turbos as well, am I correct?
fishslapper
Vehicle: 1994 lwb l400
Post by fishslapper »
just 1994 l300 =water cooled turbo.
The Mighty Boosh !!
Pacific JDM Parts
Post by Pacific JDM Parts »
Yes all 4M40 engined vehicles have water cooled turbo's.4D56 engine in 1994 model year L300 has water cooled turbo also as well as coolant operated cold start fast idle on fuel pump (no more hand throttle), different glow plug system,different timing and balance shaft belts and different pistons and cylinder head design to pre 1994 modle year L300.
Hope this helps
Paul
ccautos
Vehicle: 92 Delica SE
Post by ccautos »
MardyDelica wrote:hi, this will be a water cooled turbo. for the newer one.
Cheers;
The coolant unit on the injection pump is a wax thermostat used to increase the idle when the engine is cold. That is why there is no hand throttle cable.
MardyDelica
:M
RaddCruisers
Post by RaddCruisers »
Cheers;
On some of the Toyotas, these have been problematic and get removed or replaced.
E4 Auto Repair Ltd.
& Radd Cruisers 4WD
Duncan, BC
250 746 8977
MardyDelica
This Delica Arrived
MardyDelica
Re: 94 Delica exceed Auto,56k, * Arrived SOLD *
Delica is SOLD:
Thank you
