L400 Front & Rear Sway Bar bushing kits
Pacific JDM Parts
Post by Pacific JDM Parts »
For sale brand new front and rear sway bar bushing kits for L400 delica.Kits are availaible in 30mm or 31mm front bar and 25mm or 23mm
rear bar.Bushings are Polyurethane and come with new nuts and washers.
Kits are $30 plus taxes and shipping.
Last edited by Pacific JDM Parts on Sat Aug 22, 2009 12:31 pm, edited 1 time in total.
ccautos
Vehicle: 92 Delica SE
Re: L400 Front & Rear Sway Bar bushing kits
Post by ccautos »
After dealing with several of these vans now through our repair shop it is becoming more apparent that almost every L400 requires new sway bar links and mounts.
Drumster
Vehicle: '94 L400 diesel
Post by Drumster »
ccautos wrote:After dealing with several of these vans now through our repair shop it is becoming more apparent that almost every L400 requires new sway bar links and mounts.
What would indicate to a driver that these links & bars are due for replacement?
Thanks.
I'm here to learn.
Knocking noise in the front and vibrations.
Jack up the front end and have someone turn the wheel full tilt from one side to another. At the end of the full turn you may see the sway bar and/or control arm move due to worn bushings.
ccautos
Post by ccautos »
The most obvious symptom is the knock rattle when driving over small bumps/uneven road. You can feel the problem by holding the sway bar and pulling up and down near the end link and near the mounting bushes. As you pull up and down you will feel and see movement in both the link and mount bush.
Pacific JDM Parts
Now with pictures
Front 30mm bar
Front 30mm bar
parts pictures 036.jpg (154.17 KiB) Viewed 3590 times
Front 31mm bar
Front 31mm bar
parts pictures 037.jpg (152.52 KiB) Viewed 3591 times
Rear 23mm bar
Rear 23mm bar
parts pictures 038.jpg (118.01 KiB) Viewed 3582 times
Rear 25mm bar
Rear 25mm bar
parts pictures 039.jpg (127.22 KiB) Viewed 3588 times
