1992 Delica Exceed 112,000 kms. (White color; No Rust)
Amazing Auto Import Ltd;
DL # 30843
Mardy (Mardydelica)
Richmond, B.C.
T- 604-247-2111 / 604-720-6144
Will do the ff. service & Details of this Delica:
1.) Will Change New Timing belt (Mitsubishi 2 Pcs), new Japan made water pump, new bearings, 4 new seals (Mitsubishi), New thermostat;
2.) Will change all fluids such as oil, gear oil, antifreeze;
3.) New transmission oil, change filter, clean transmission pan;
4.) New depot headlights with 4 new osram bulbs (Made in Germany);
5.) Comply & register with day time running lights;
6.) 4 brand new tires;
7.) Undercarriage will be re-greased;
8.) With complete Curtain front & rear as you can see
9.) 1 yr. or 12,000 kms warranty - which ever comes first (Power train);
10.) New anti-sway bar bushings upper & lower (Poly-urethane);
11.) No rust in the roof & under
12.) Runs very good & stable;
13.) 7 passengers;
14.) We reseal the front panels on all our Delicas ,so you won't have to worry about floor leakage.
15.) Will do Pass compliance Prov. inspection. so nothing to worry about compliance will do it for you. all you need
is to registered it under your name. thats simple.
16.) Previous owner in japan upgraded it to jasper Crome bull bar ,side step, rear bumper & rear ladder. which is nice to upgrade. its a nice clean car.
17.) Install Brand New radiator
any other question Pls call me:
Cheers:
92 Delica exceed Auto,112k white No Rust * SOLD*
- MardyDelica
- DSCN9967.JPG (85.78 KiB) Viewed 2989 times
- DSCN9979.JPG (82.81 KiB) Viewed 2986 times
- DSCN9977.JPG (84.64 KiB) Viewed 2985 times
- DSCN9974.JPG (82.3 KiB) Viewed 2985 times
- DSCN9970.JPG (78.15 KiB) Viewed 2985 times
- DSCN9975.JPG (69.88 KiB) Viewed 2986 times
- MardyDelica
Re: 92 Delica exceed Auto,112k white No Rust $10,200 Japan Stock
More Pictures:
- DSCN9984.JPG (95.35 KiB) Viewed 2971 times
- DSCN9987.JPG (86.79 KiB) Viewed 2967 times
- DSCN9992.JPG (92.73 KiB) Viewed 2962 times
- DSCN9991.JPG (92.27 KiB) Viewed 2963 times
- DSCN9989.JPG (90 KiB) Viewed 2956 times
- DSCN9990.JPG (90.76 KiB) Viewed 2955 times
- MardyDelica
more pictures:
- DSCN9983.JPG (79.56 KiB) Viewed 2937 times
- DSCN0003.JPG (86.13 KiB) Viewed 2935 times
- DSCN0002.JPG (89.89 KiB) Viewed 2929 times
- DSCN9980.JPG (88.07 KiB) Viewed 2923 times
- DSCN9973.JPG (91 KiB) Viewed 2921 times
- DSCN9981.JPG (85.78 KiB) Viewed 2913 times
- MardyDelica
More Pictures;
- DSCN9969.JPG (81.84 KiB) Viewed 2900 times
- DSCN9971.JPG (76.06 KiB) Viewed 2892 times
- DSCN9993.JPG (76.22 KiB) Viewed 2888 times
- DSCN9996.JPG (83.77 KiB) Viewed 2886 times
- DSCN9993.JPG (76.22 KiB) Viewed 2881 times
- MardyDelica
Re: 92 Delica exceed Auto,112k white No Rust On Hold in Transit
Hi, this delica is on hold,
recieved deposit
Thank you
recieved deposit
Thank you
- MardyDelica
