Windshield-Crack
- impalator
- Vehicle: L300
Windshield-Crack
When I attempted to fix the "Wet-Footwell" issue about 2 months ago, I had a really hard time, 1st, getting to the screws under the rubber-window gasket and 2nd opening it as it was pretty much rusted on.
So while working away on that screw, I must have applied just a tiny bit too much pressure towards the windshield with the flat screwdriver holding the gasket up - and "crush!" I managed to get a tiny little (1.5 cm) crack in the glass.
Over the weeks since this incident, the crack has grown to a respectable 7 cm's and appears to not want to stop.
I will definitively wait out the winter before attempting to have the windshield replaced.
But since many of you Delica-Fans are driving on logging roads and go up north / to the interior, I must assume that I am not the first one with a cracked (or chipped) windshield.
Would I just go down to the North Vancouver Broco Autoglass? Or do I need to go someplace special for such Mitsubishi Windshields? Are they readily available or is it a "pain in the butt" to get them here?
Thanks in advance for any suggestions.
Chris
Chris
- konadog
- Vehicle: 1992 GLX L-300
Re: Windshield-Crack
We had a cracked windshield (rock from a truck
) last summer. I called a couple of glass shops here in CR and one guy said he had done other delis and could get them and that he would call me back - but never did. I ended up getting a new one from ccautos. Make some calls though, as I bet some ICBC glass shops about will be able to get them: MB421735
http://wikrad.com/delica/index.cgi?wind ... _mouldings
Mardy from amazing auto has a couple of delica windshields in his shop. Reasonable prices too.
I had my windshield replaced in Sidney at Capital City Glass - they are one of the ICBC express glass shops and they had no problem sourcing a windshield for my van, so I suspect that any ICBC express shop could do it - but remember to say that your window was cracked by a projectile and not your own actions.
- jwfchase
- Vehicle: '92 Super Exceed
They can also sometimes attempt a repair to stop the crack from worsening- doesn't always work, but if it does it could keep your 7cm break from spreading all over the place before springtime.
- impalator
- Vehicle: L300
As a further update to the saga of trying to dry out the footwells which led to the crack in the first place: They continue to be wet - and today I have (upon recommendation of Butch from CVI) paid a short visit to Vision Autoglass (Jeff Freeman) on Bathgate (behind IKEA in Richmond) and he squeezed some black urethane sealer below my windshield gasket.
As I had told him that my cracked windshield would need replacement once the nice weather is here again, he actually performed the 20 minutes procedure free of charge - I am definitively a customer who will return once I will have to replace my windshield. Thanks Jeff - really appreciated!
For anybody with wet footwells: Don't "just" reseal underneath the two front side panels as described in other posts - but have your windshield seal also checked / sealed!
Chris
Chris
- Vehicle: -
Well, I resealed it all the way around with black urethane sealer (and did all the other stuff), but is still wet. It's getting really annoying....impalator wrote:For anybody with wet footwells: Don't "just" reseal underneath the two front side panels as described in other posts - but have your windshield seal also checked / sealed!
I hear you one the wet foot thing - did the front quarter panels and windshield and still wet. A 3rd possible place is the top weld on top of the A pillar where the gutter ends - some people have had some luck reducing water inflow by sealing that area -apparently a crack can form there and there is also a body seam that has the same kind of sealant as the quarter panel - not sure how one would even attempt to redo the sealant.
- Vehicle: -
I already done this as wellquadzilla wrote:I hear you one the wet foot thing - did the front quarter panels and windshield and still wet. A 3rd possible place is the top weld on top of the A pillar where the gutter ends - some people have had some luck reducing water inflow by sealing that area -apparently a crack can form there and there is also a body seam that has the same kind of sealant as the quarter panel - not sure how one would even attempt to redo the sealant.
- kidwrecked
- Vehicle: 92 Jade High Roof
Just a thought, but since I have my van front end in pieces, I have noticed that there are a lot of holes that go right through to the interior that are behind plastic panels and plastic screw anchors. You may want to stick your head under the dash with a good light (WAAAYY under the dash) with someone outside with a high pressure hose. Have this someone spray the hose in many directions (up, down, from side to side, ect) to re-enact driving throug the rain, and see if you can see where any drips might be coming from. Possibly it ight be from a broken plastic tab or a failed plastic tab gasket.
Andrew
Andrew
Almost forgot about the front panel clips behind the Mitsubishi face plate or whatever it is called - apparently the grommets and seals can shrink and water can penetrate through there, too. So - kidwrecked's idea is a good one and would probably reveal if that was the source of the water.
- impalator
- Vehicle: L300
Any tips or ideas on how to remove the Mitsubishi face-plate / plastic grille or whatever it is called?
Since I already cracked my windshield when sealing the front quarter panel seams I would hate to also crack the "Mitsubishi Plastic Front Cover"..
Thanks and regards,
Chris
Thanks and regards,
Chris
I haven't tackled this yet, but it looks like the bush bars need to come off, then the removal should be relatively straight forward - but then again, the easy things always seem to be harder then one hopes! I plan on trying this in the spring.
- loki
if you mean the long plastic body panel between the headlights it just pulls straight out, can be hard the first time as it likely hasn't moved in a long time.impalator wrote:Any tips or ideas on how to remove the Mitsubishi face-plate / plastic grille or whatever it is called?
Thanks and regards,
Chris
