45,200 KMS
235/75/15 Hankook Tires
Very Clean with 4B Grade
Skylite Roof Middle Non Functional
No Floor Leaks Visible
Service Pack:
DRL
High Mount Brake
Battery Terminal (Cleaned)
New Headlight Replaced
Side Marker Installed (Front / Rear)
Brake Pad Checked
Rotors Checked
Front Wheel Bearing / HUB Greased
Front Axel Inspected
Ball Joint (Checked)
Tie Rods / Steering Link (Checked)
All Suspension Parts Regressed.
Shock Absorber (Checked)
Fluid
Coolant Flush
Fresh Coolant
Engine Flush
Fresh Oil Chevron Delo 400
Power Steering
Clutch Fluid Checked
Brake Fluid Check
Gear Oil
Differential Oil
Mechanical
REPLACE IF NEEDED.
Thermostat (Check/Replace)
Water pump (Check/Replace)
Radiator Cap (Check /Replace)
Power Steering Belt
Alternator Belt
AC Belt
Filter:
Air Filter
Fuel Filter
Oil Filter
New Wipers if necessary
All Hinges Greased
All Bulbs Checked
Tire Pressure Check
Complete Detailing Package (Interior, Exterior, Enigne)
