Good Lube Place
- daveyboy70
- Vehicle: 1991 Delica Super Exceed
Good Lube Place
Just wondering if anyone can reccommend a good drive thru lube place in Richmond or Vancouver area. It is much too cold out.and I am due for a change.
Re: Good Lube Place
Honestly? I would recommend CVI, on the north end of Shell Road. They understand your machine and will give you explained options to choose from. That is where I go.
jfpdelica
- Vehicle: Mitsubishi Delica 35w
Re: Good Lube Place
I often have to agree with Falco, CVI is indubitably the #1 spot for these vehicle. He won't waste your time or money. Good luck JeffFalcoColumbarius wrote:Honestly? I would recommend CVI, on the north end of Shell Road. They understand your machine and will give you explained options to choose from. That is where I go.
sayulita101
- Vehicle: 92 delica super exceed
Re: Good Lube Place
Pay the extra 15$ for the Moly oil they offer you can feel the difference in the smoothness of the van at idle.I think they charge 90$ and thats with a Japanese filter.
Paul
Paul
- Profister
coaxial
Re: Good Lube Place
I agree CVI is the best, but if you can't get out to richmond a good backup is http://www.mrquick.ca/ , I go to the one in north van for oil changes (rather than doing them in my street). They carry the filter, know all the grease points, and check all sorts of things (leaks,battery,alt,coolant,belts,lights,tires,etc.)
- daveyboy70
Re: Good Lube Place
Thanks for the tip - I visited CVI today and they did not disappoint, can learn a lot about the Deli while they are doing the change as well. $60.00 for the change I supplied the filter. I picked up one from Mardy a week or so back.
- On the hoist at CVI
- IMG00070_1.jpg (154.31 KiB) Viewed 4118 times
