I just have to say this is all Jesse`s fault.
All his talk of air lockers got me thinking.
Since the intercooler is now all sorted, I spent this week installing a complete compressed air system in the van.
Being a truck mechanic, sourcing the tank, #4 plastic air lines and fittings was easy. any truck shop has all this.
the superflow compressor and pressure switch came from northshore offroad. the pressure switch turns on the relay that powers the compressor, at 85 psi, and off at 105.
Now dropping tire pressure for more traction will be an option. the yellow curly hose plugs in a bunch of different spots so I can easily reach all 4 tires.
Just behind the passenger seat is a blowgun which will make cleaning the dust and pineneedles easy.
And the main reason, LOCKERS of course.
onboard air system
- garyo
- Vehicle: 91 exceed
onboard air system
- side view air tank.jpg (71.52 KiB) Viewed 3679 times
- pressure sw. in blue air manifold turns compressor on @ 85 psi. off at 105 psi..jpg (93.36 KiB) Viewed 3678 times
- superflow compressor mounted to bed frame at right rear corner.jpg (81.76 KiB) Viewed 3677 times
- semi trailer air tank now where muffler was.jpg (65.96 KiB) Viewed 3686 times
- air blower for keeping the cab clean.jpg (76.26 KiB) Viewed 3678 times
- Luna-Sea
Re: onboard air system
Holy Molasses!
Two Questions 4 ya!
I just want to know what kind of toothbrush you are using on your engine and what is on the other end of end of the cantelever extend-o- gate in the third pic beside the compressor(either a shaving mirror or a boxing glove!) ?
Amazing Work man!
Also what product did you use on your tank/rear dif/leafs ,judging by the great lengths you have gone to with your other pursuits it is no doubt some worthy of mention product.
I am still stunned by the intercooler project thing garyo and now this!
There is only so much a guy can take!
Right on!
Two Questions 4 ya!
Amazing Work man!
Right on!
- DelicaMark
- Vehicle: L400
That is awesome! Maybe I could lend you my van for a month or two and just see what happens.
- delicat
DelicaMark,
That would be a bad idea, you'd get it back with a bunch of parts missing
And Garyo's van would be sporting them!
Garyo, do you just paint over the dirt to keep her that clean looking?
