93 Mitsubishi Jasper Clean!
mdrive
Post by mdrive »
1993 Mitsubishi Delica Jasper Loaded $11,200
Features:
Cold Climate Package,(LSD, Dual Battery, Thick Carpet)
Automatic
Power Window
Air Conditioned
8 Seater
2.5 Lt Turbo Diesel
112,000 KMS
4 Brand New Yokohama Geolander Tires
Stainless Steel Roof Rack and Rear Ladder
Servicing Completed:
New Timing Belt, Balancer Belt, 4 New Oil Seals, Tenioners, Waterpump.
Engine oil, coolant, rear differential fluid, brake fluid, power steering replaced.
All filters replaced
New Radiator, Rebuilt Fuel Pump.
New Sway bar bushings replaced
Delica Tune completed: Fuel Pump adjustments, Injector Cleaning, Valve Adjustments.
All suspension parts regreased.</i>
Brand New Rotor, Brake Pads, Inner and Outer Hub Bearing.
Re: 93 Mitsubishi Jasper Clean!
Nice 'Jasper' detail on the 'roo bars. Never seen that before. Seen the 'Chamonix' ones, but not this one.
