hello guys, I am a new to this forum, but Some of you might hear "MONKY'S INC" name in this forum.
We sold 2 delica to a member of this Forum, "dean", and Unfortunately BY OUR MISTAKE, MISS INFORMATIONS We gave him much "Stress", and "Loss" on his shopping at us. We appologized all this issue to him and We got his reply by e-mail. We recognize that "Dean" accepted my compensation for this issue, so this time I decide to introduce my company service, etc on this forum.
We've been changing, updating my company webpage "Canada sections" for informing more detail informations clearly, so if you guys are interesting to import vehicles from japan, please visit webpage, and let us know your opinions, requests, etc... if you would found something..
"Dean" comments on this forum, you can find this Link URL, Please read this, and if you would feel "no problems", contact anytime, We are welcome your PM, mails, request via our webpage...
Subject "Anyone bought from Monky's?"
http://www.delica.ca/forum/anyone-bough ... -3383.html
I believe he understand all my situations, accept my appologizes...
Here is the vehicle informations Now for sale in our inventory...
Vehicle Specifications
Make: Toyota
Model Name : Hilux Surf SSR-X 3.0 Diesel Turbo 4x4 wide body
Model: Y-KZN130W
Year: 1993/8
Mileage: 61,000km
Body Colour : Charcoal Grey metalic(Colour # "179")
Engine: 1KZ 3L 4Cyl EFI Turbocharged Diesel
Gas/Diesel/Propane/other: Diesel
Transmission: 5spd
4WD type : Selective, manually controlled(Shift button & Shift type)
Location of Vehicle: Ibaraki-city,Osaka,Japan, In MONKY'S INC STOCK YARD
Vehicle Features
Interior : Grey(Trim # HW11)
Power steering : Yes
Tilt steering : Yes
Power Window : Yes
Power Mirrors : Mirror angle powered, Foldable type(No electric folding)
Air Conditioning : Manual Type Air conditioning
Audio : Toyota Genuine CDNavigation TV/AM/FM/CD/Casette 2DIN type
Wiper : 1-Interval 2-normal 3-High speed, and Rear wiper
Other Options :
@Adjustable damper
@BOSCH Fog lump
Vehicle Sales point
Sales Point:
@Very Low km, only 61,000km Certified.
@Rare 5spd Model
@Very Clean, No rusts Chassis, Good mechanical Condition
Please see the engine bay Pics! This shows you "Original Beauty" of The Plastic,
the metals, all materials. We don't spray any "Artificial-Chemical Glitter Spray".
Cleaned all up very carefully, then took this picture.
Most of Pictures available at Japan Car Exporter Inventory, "Very shine engine bay",
that's just "Sprayed", Greasy, Harmful for Engines, Wires, Plastics, and for
Human being. If you like More "Glitter engine", Yes, Of course, We spray it all.
We are following to custmer requests.
Negative issues:
Some tiny size dents, scratches.
We already did "Machine polishing & Polymer coating", It's very hard to remove such scratches, dents.
We show all dents, and scratches "still be on the panel" Even though We Polished.
The only way to remove those dents, "Paint job", or "Body job" only.
@Front left flare fender "paint off", 1to2cm size paint "Removed".
We can "Touch up" without any additional fees. If you would request us
complete paint job, 10,000JPY.
@Rear Quarter (Left and right) has a 2cm, circle dent.
@Passenger side door has a parking dent, size is very small.
All scratches, dents are tiny size.
@Passenger side Dashboar has very small, 4holes, repaired.
It must be "TV-Lack"mounted by small bolts, Now We are repairing
the holes carefully, so We will update the "Finishement" pics soon.
We have a "body condition" video, show around body panel, As your requests,
We can send it by E-mail.
Inspection Report
All Vehicles in our inventory are basically inspected in fully,
following to Japan every 2year inspections called as "SHAKEN",
MONKY'S INC mechanical factory in Toyonaka city, Osaka, Japan is an
Kinki District M.O.T Registered and Liscensed Workshop.
(Minkan Shaken ninsho kojyo in Japanese).
Report paper Translated here :
report here:
1. Engine room inspection
@Vbelt
Changed with New Vbelts by us before SHAKEN.
@Battery Terminal :
No rusts, Both battery voltage OK.
@Engine
Colour of exhaust gas : Clear, OK
No making noise, oil leakage from the crank case, other places.
Air cleaner : Not very dirt, OK
@Fan Belt :
Not loose, no crackes, worn on the belt surface
2. Suspensions inspection
@Brakes
Front Disk pads : New pads installed(5mm before we changed)
Rear Brake shoes : New Shoes installed (4mm before we changed
The clearance between disk rotor to Pads, and Shoes and wheels, OK
The rotor surface OK.
@Tires: 2 to 4mm to Slip line all 4tires
@Brake Master, cylinder, etc
No leakage from Master back, Wheel cylinder, Front disk caliper pistion seals, and rear drum pistion seals, OK.
@Wheels, nuts
We removed rims, drums, then assembled again on proper torque, OK.
3. Underchassis inspection
@Engine oil leakage
No leakage seen
@Transmission Oil leakage
No leakage, Level, dirtness OK
@Propeller shaft, Driveshaft
Both No making noise, shaking.
Driveshaft Boots not new, but Not teared, broken, OK
Bolts, nuts torque OK
@Brake hose, pipes
No leakage, cracks.
@Exhausts
Outer cover has surace rusts, But not problems now.
@Suspensions
No Oil leakage, No making noise on test driving, shaking by hands.
4. Daily Inspection
@Brake fluids : Within Low to High lelve
@Tire pressure : Inflated at 2,3kg/cm all 4tires
@Tire surface : see some tiny cracks on the tread rubbers
@Battery water level : within low to max, nearly max level now.
@The level of Anti freeze coolant : within low to max in Reservoir.
Mixture level ok for our area(max minus 5degree)
@Engine oil: Already changed by us at 60,800km Odo,
Oil : AMS OIL 100% Synthetic Heavy Duty & Marine Diesel 15W-40.
Filter : Changed at the same time.
@Safety Devices
Wiper : OK
Horn : OK
Hazardous lump : OK
Turn signals : OK
Headlight : Low and high OK, No cracks on any lens, glass
Front glass : No cracks
This Hilux Surf Truck passed "SHAKEN" at our mechanical workshop.
SHAKEN is not the Test, and the certification, which guarantee the vehicle is Perfect Condition vehicle,
However, This Test is required for Every vehicles , driven legally in japan road, one of good test to
show the vehicle runs good, stop safely, No seriuos mechanical damages, Good condition.
Price Terms
We usually offer 2 different Prices, "With service", or "Without services".
This Hilux Surf already Reconditioned Completely at our workshop, and a couple of
New parts "Installed" on this unit already, So Offer price is "With Service" price only.
PRICES
(With Services, We call this BASE PRICE)
C.I.F New Westminster (Vancouver) port Canada 1,080,000JPY
Parts we changed list here:
@Vbelts
@Front brake pads, Rear brake shoes.
@Lube up(Grease up points)
@Body machine polished, Long lasting polymer coating
@Interior, Engine bay, all cleaned up
@Chassis, Frames, cleaned up, painted up.
@Anti freeze coolant : Add as your request weather conditions
All these labor and service fees included in the above C.I.F price.
If you would like to "Glitter plastic finishment", We use Famous Armorall protectant on dashboard, and rubber parts, But We personally hate "Greasy surface", Unless we have this requests, We don't spray such "Silicone spray" , except "Tire sidewall".
2. Shipping Info
Methods : RORO Shipping
Carrier : Nissan Car Carrier(NCC)
Departure port : Osaka port, Japan
*Yokohama port also available, additional 30,000JPY Local
Transportation fee required on Yokohama departure shipping case.
Destination port : Vancouver(New Westminster) port, Canada
Booking : A RORO schedule avaialble "FROM OSAKA PORT" monthly.
3. Delivery Schedule
After we confirm the custmer bank transfer Full CIF payment at our
bank account, We immediately try to book NCC RORO service, then
inform the custmer about the schedule.
We contracted with NCC, has enough space on each RORO boat leave
japan for Canada Monthly on schedule. Depends on the payment confirmed date, The shipping schedule changed
We can reply your questions, request by e-mail, or PM via This forum,
Please contact YAS freely,
We have
4 Video files (Windows media file, WMV file type).
@TEST DRIVING(In City area, 0 to 60km/h)
@BODY DENT, SCRACHES CONDITION
@UNDERCHASSIS CONDITION
@LIGHT, SIGNALS, P/W, GATE GLASS, ETC TEST
180 total Different angle, 800X600pixel colour pictures. We can send as your requests.
If you would like to see "Samples" of vehicles, We did "Services", We can
send many example pictures of This kind of Mini truck, Sports, SUV, any kinds
of vehicles we've been selling to canada market since 2003year.
1993/8 Hilux Surf SSR-X 3.0DT 5spd Wide Body
Yas_monkysinc_japan
- Vehicle: Mitsubishi Pajero V24 Lug top
- 800CIMG9149.jpg (82.63 KiB) Viewed 6355 times
- dents, scratches "Visible" on the body panel.
- 800CIMGdents.jpg (89.27 KiB) Viewed 6355 times
- Clean interior...
- 800CIMG9428.jpg (87.64 KiB) Viewed 6352 times
- Very clean engine bay, We don't use any "Glitter, Fake beautiful sprays" on any parts of Engine bay. you can touch, kiss it, no problems.
- 800CIMG9488.jpg (119.22 KiB) Viewed 6352 times
- Please see the chrome parts, bumpers, etc.. shines!
- 800CIMG9498.jpg (113.94 KiB) Viewed 6349 times
- Any places, door back side, etc, already cleaned up completely
- 800CIMG9371.jpg (89.47 KiB) Viewed 6346 times
- chassis already steam washed, removed a minor surface rusts, then painted completely.
- 800CIMG9206.jpg (94.26 KiB) Viewed 6346 times
jymz
Re: 1993/8 Hilux Surf SSR-X 3.0DT 5spd Wide Body
I once purchased a skyline from Monkeys only to find they sold it to a guy in Austrailia for more money after I paid for it. Do yourself a favour and search these guys. So shady, even Japanese companies don't deal with them.
Notice how the bottom of that truck got a repaint. Yeah thats sounds normal.
That is my opinion.
That is my opinion.
Yas_monkysinc_japan
Hi jymz,
>>I once purchased a skyline from Monkeys only to find they sold it to a guy in Austrailia for more money after I >>paid for it. Do yourself a favour and search these guys. So shady, even Japanese companies don't deal with >>them.
Let me have chassis number of the skyline you purchased? We have all vehicle records what kind of service We did for Custmer purchased vehicle, like "Without service, as is condition", or "With servicing" in details, , so I can show any detail info openly , publicly here the board even though the vehicle sold many years ago? , and I can hear your complains in details if you have had, or still have? , very helpful for me to offer more quality better custmer service and better for persons who are interested in purchasing cars at MONKY'S INC, Please let show the vehicle info on this page?? I belive you have no problems to show just only chassis number?? if you purchased it, and you says it was sold by us.
Yes, Repainted, Of course Repainted completely at our mechanical workshop by mechanics.
haha, not a way for "Hide rusts"... Most of cars We "Inspected", and "Cleaned up before shipping japan", basically Painted fully. HOW?? that's very simple, Canada is Mostly Snowing area country than japan, To prevent rusts is big issue?? Most of custmer welcome our these service?? I feel you want to say "very doubtful", personally I think so, if not Sorry appologize , I attached "Chassis pics", BEFORE WE DID PAINT PROCESS..
People knows that We cleaned up completely the chassis, then paint the chassis.
>>That is my opinion.
I don't feel any "Bad" against you, thanks for your nice message who might be interested in purchasing this unit, and They will take your "opinion" into their considerations, good. But
That's very annoyance for other custmers who has been dealing with us for many years.. if you would not shows any clear issues, or certified, like show the skyline pictures, how shady the skyline? I feel it seems like "Unfair"...
I have no problems, saying any of me, monky's. Actually We know it's very difficult to give "Satisfaction guaranteed" to all custmers we deal with...
Those pics are organize by Photoshops, because so darker by reflections, to everybody see more clearly than original pics, dirt, greese, etc... not intend to "Hide problems"...
Basically We explains in detail in our webpage, We shows all "Process pictures" to custmers before we deal with... step by step pictures... so We record these pictures so as to show all details...
anyway thanks your message, any opinons welcome at me, YAS,
>>That is my opinion.
- horsing case, chassis, before cleaning process..
- 800CIMG9066.jpg (138.16 KiB) Viewed 5986 times
- before Cleaning process. same as it is, not washed...
- 800CIMG9068.jpg (100.87 KiB) Viewed 5984 times
- undercover also removed, checked, washed, then painted..
- 800CIMG9091.jpg (99.12 KiB) Viewed 5985 times
- after painting process..
- 800CIMG9105.jpg (142.79 KiB) Viewed 5987 times
jymz
Hi,
Thanks for your more than thourough explanation.
The car I purchased from you was 28 drift cars ago. You see I worked in the industry and my boss called you and talked to you on three occasions and we also called the party in Austrailia to confirm it was indeed the car I purchased from you.
The reason it was so obvious was that the car itself was very unique. DOwn to the mismatched wheels, coloured roll cage, specialty engine parts. Either way I didn't bother with the first post to stir up shit for you three years later only to come back and explain myself. I sent you $2500 deposit and you sold the car to an aussie buyer and told me my car was having problems in port with loading.
So frankly, eff your explanation. The aussie market just added that model to their allowables list and you took advantage of it at the time. I don't need to dig up pics of the car. But in the fitire, if you are selling a driftcar, you might want to remove the local osaka drift teams sticker from it, that way I'll know it's not the same effing car so easily. Tard.
PS it's really too bad because we have nearly the same taste in cars, wish it went differently.
Yas_monkysinc_japan
We didn't sell any Skyilne with roll cage...
except a white skyline GT-R shipped to "Netherland", final destination Slovakia...
If your story is true, You'd better to show the vehicle pics...
We show most of cars sold in past, in canada section webpage, so people see this thread can check the car you "Talk" is the car we sold or not.. Does this make sense?
I don't care any stories, but "Telling a lie" is no good.
Yas_monkysinc_japan
I forgot mention this...
We usually put the "Stock Number", and "Vehicle chassis number" in the proforma invoice,
beforew we accept "Payment". so Please show/post the Vin number here, We can trace which car
you mentioned?.
We have all vin (Japanese chassis number) number of cars we sold in past, We can judge your story is true or false, and people see this threads understand all.
YAS,
you mentioned?.
YAS,
