I'm in the market for a Delica. Wondering if someone could provide me with the height of the P25W vs P35W. I am hoping it might fit into my garage? Also any major engine differences between the 91 to 93 model year vehicles as far as performance, fuel economy?
I'm living in BC...any feedback on Delica importing dealerships with a solid reputation would also be appreciated. Don't mind traveling to the coast or island to pick one up.
general specs height & fuel economy
kootenay
- Vehicle: looking
- The Pinkfingers
- Vehicle: '94 Exceed
Re: general specs height & fuel economy
Welcome to the forum.
A quick use of the search feature will answer all your questions. But in brief:
High roofs are a little under 7 feet (about 6'11"). The low roof is about 6'6".
Fuel economy: http://www.delica.ca/forum/expected-fue ... -3177.html
Dealer feedback: http://www.delica.ca/forum/delica-deale ... -3086.html
Any other questions, try the search feature first, then if you can't find what you're looking for, write a post. You'll find this group to be a friendly bunch!
- MardyDelica
the there is no difference between 1991 to 1993 except , 1993 starting june P35W-0400000 ,it change the engine glow plug, with glow plug sign in the speedometer cluster. also it has a water cool cold start valve attached toward the injection pump for new 1993 delica no more throttle cable attached on it.
if your looking for some delica i ahve some in stock,
just give me a call anytime.
Cheers;
Cheers;
- Erebus
- Vehicle: 1992 Super Exceed
Starting with August of 1991 production, so mostly 1992 models, the rear captains' chairs and the outside 2 positions of the rear bench had shoulder belts standard. Also centre mounted brake light became standard, which blocks the interior lock button (but there is a work-around available)
