FOR SALE! 1993 DELICA JASPER
fivestarauto
Vehicle: Delicas
Post by fivestarauto »
1993 Delica Jasper addition 137,000 kms,ICBC inspected, come with a one year lubrico warranty good across north america! $5,347 spent in wholesale parts and labour (coombs country autos) things done such as: carryout all necessary service and reairs for DOT, oil filter, new oil, tiing belt, balance belt and drive belts, timing belt tensioner kit, front engine oil seal set, used rocker shaft assembly, valve cover gasket set, water pump, thermostat, radiator cap, recored radiator, upper and lower radiator hoses, hose clamps, engine mounts, DOT headlamp set, corner marker lamps, DRL module, headlamp bulbs, inner and outer tie rod ends, teering rack boot kits, front sway bar bush kit, front brake rotors, front brake pads, front shock absorbers, wet batteries, wiper blade set, used steering wheel, antifreeze. new 10 ply nexen tires as well with 120,000 km warranty!
any more information please feel free to contact us! 250 248 8311 or http://www.fivestarautosales.ca
ccautos
Vehicle: 92 Delica SE
Re: FOR SALE! 1993 DELICA JASPER
Post by ccautos »
This is one clean van . Highly recommended due to its clean underbody and extensive `no expense spared` maintenance and repairs .
