Anyway, would you be so kind and answer the following questions:
1. There appears to be no cruise control on the currently imported Delicas. Lucky 8 Auto advertises at autotrader.ca that their Delicas do have cruise control. Is it throttle control they are referring to, or do they install the real cruise control somehow?
2. Does anyone know when Mitsubishi started installing cruise controls on Delicas? 1995? 2000?
3. Is there any shop in the Lower Mainland which would install RV batteries and an inverter inside a Delica? Has anyone on the board had it done? Costs? Happy?
4. What are the interior dimensions of Delicas? Are some larger than others? Especially interesting is the distance from the back of the driver seat to the hatch.
5. How hard is it to remove all the passenger seats from a Delica to make it a camper with a flat floor?
6. Do all Delicas have the same 4x4 systems, or some are more advanced than others? Is there a center differential lock? Anything else 4x4 related in addition to lower gears?
Thank you, thank you, thank you
