1991 Delica Super Exceed 56,350k(white) *SOLD*
MardyDelica
Post by MardyDelica »
For sale: 1991 Delica Super Exceed 56,350 kms. In-Transit (White color; No Rust)
Price: $ 12,500
Amazing Auto Import Ltd;
DL # 30843
Mardy (Mardydelica)
Richmond, B.C.
T- 604-247-2111 / 604-720-6144
1.) Will Change New Timing belt (Mitsubishi 2 Pcs), new water pump (Japan), 2 new bearings, 4 new seals (orig mits), thermostat;
2.) Will change all fluids- oil, gear oil, antifreeze, etc;
3.) New transmission oil, change filters, clean transmission pan;
4.) New Depot headlights with 4 new osram bulbs (Germany);
5.) Will Comply & register with day time running lights;
6.) Brand new tires;
7.) Undercarriage will be re-greased;
8.) 4 New pro-comp shocks 9000 series;
9.) 1 yr. warranty or 12,000 kms which ever comes first (Power train);
10.) New anti-sway bar bushings upper & lower (Poly-urethane);
11.) LSD Differential;
12.) 2 batteries, designed for Winter package;
13.) No rust on the roof & Undercarriage. Clean Delica;
14.) Runs very good & stable;
15.) 7 passengers;
16.) Will get done full compliance, service and inspection, all you need is to insure it;
17.) We fix front panel seals on all our Delicas, to prevent the "wet floor syndrome";
18.) All The Shades work which is Nice & a Bonus.
MardyDelica
Re: 1991 Delica Super Exceed 56,350k(white) *In Transit*
Hi, This Delica is on Hold,
Future Owner put a deposit,
Cheers;
MardyDelica
Re: 1991 Delica Super Exceed 56,350k(white) *Arrived*
Delica Arrived
Cheers;
sasquatch-hunter
Vehicle: 2 Delica
Post by sasquatch-hunter »
Hi Mardy,
What are those green light thingies hanging down?
cheers,
seb
MardyDelica
Hi, those where the original humidifier from mitsubishi.
cheers;
MardyDelica
Re: 1991 Delica Super Exceed 56,350k(white) *On-Hold*
Update. On Hold with deposit.
thanks
MardyDelica
Re: 1991 Delica Super Exceed 56,350k(white) *SOLD*
Hi, This Delica is SOLD:
Thank you
