For sale:1992 Toyota Previa(Lucida)
Price $ 9000
Amazing Auto Imports Ltd
Mardy ( MardyDelica)
DL# 30843
Stock # A-45928
Richmond , B.C.
604-241-1111 / 604-720-6144
Will do the ff. service & Details of this Toyota:
1.) Timing belt recently changed
2.) Will change all fluids such as oil, gear oil, antifreeze;
3.) New transmission oil, change all filters, clean transmission pan;
4.) Will Modify headlights to pass inspection;
5.) Comply & register with day time running lights;
6.) 4 brand new tires;
7.) Undercarriage will be re-greased;
8.) 8 Passenger car all with orig, Toyota seat belt;
9.) 1 yr. or 12,000 kms warranty - which ever comes first (Power train);
10.) New anti-sway bar bushings upper & lower (Poly-urethane);
11.) Has a Middle 3 point seat belt good for your family & kids ;
12.) Rare low mileage 4x4 (AWD) Previa (Lucida in Japan) Diesel. Most parts interchangeable with Previa;
13.) Clean car as you see in the pictures;
14.) 4 Cyl, 2.2 liter Turbo Diesel, with Dual air conditioning ( Front & Rear ) and 5speed Transmission;
15.) Runs very good & stable;
16.) Rare Nice teal color;
17.) will inspect rotors, pads and/or shoes and replace if needed & repack the front hubs & bearings;
18.) Will Do detailing of this Previa.
19.) Equipped with "sonar" back-up/forward alarm system - essential for blindfolded parallel parking!
For additional pictures and other cars, feel free to browse through our website
This is a grade 4A vehicle, meaning it's the cleanest possible with mint mechanical, body and interior.
Toyota Previa(Lucida) 105k Blue 5spd Turbo Diesel
- MardyDelica
- DSCN3321.JPG (88.29 KiB) Viewed 3042 times
- DSCN3323.JPG (85.09 KiB) Viewed 3042 times
- DSCN3331.JPG (82.87 KiB) Viewed 3041 times
- DSCN3336.JPG (93.8 KiB) Viewed 3040 times
- DSCN3347.JPG (69.19 KiB) Viewed 3038 times
- DSCN3350.JPG (71.47 KiB) Viewed 3035 times
- DSCN3352.JPG (85.53 KiB) Viewed 3036 times
samsplacci
Re: Toyota Previa(Lucida) 105k Blue 5spd Turbo Diesel
is it full time AWD? or is there an option to roll at 2wd? This van certainly appears to be in amazing condition. Any idea how this rig is on fuel ie, estimate on L/100km?
- MardyDelica
Hello
Thanks for your interest
This car is all time AWD
Not sure exactly, however they are less rugged, lighter than Delicas, so despite of AWD it will get a bit better mileage.
My estimate is somewhere between 25-30MPG.
Previas have a different gear ratio to the Delicas as well.
samsplacci
thanks Mardy.
- MardyDelica
