Will do the ff. service & Details of this Toyota:
1.) Timing belt recently changed
2.) Will change all fluids such as oil, gear oil, antifreeze;
3.) New transmission oil, change all filters, clean transmission pan;
4.) Will Modify headlights to pass inspection;
5.) Comply & register with day time running lights;
6.) 4 brand new tires;
7.) Undercarriage will be re-greased;
8.) 8 Passenger car all with orig, Toyota seat belt
9.) 1 yr. or 12,000 kms warranty - which ever comes first (Power train);
10.) New anti-sway bar bushings upper & lower (Poly-urethane);
11.) Has a Middle 3 point seat belt good for your family & kids
12.) Rare low mileage 4x4 (AWD) Previa (Lucida in Japan) Diesel. Most parts interchangeable with Previa.
13.) Clean car as you see in the pictures
14.) 4 Cyl, 2.2 liter Turbo Diesel, with Dual air conditioning ( Front & Rear ) and AUTO transmission.
15.) Runs very good & stable;
16.) Rare Nice blue color
17.) will inspect rotors, pads and/or shoes and replace if needed & repack the front hubs & bearings.
18.) Will Do detailing of this Previa.
For additional pictures and other cars, feel free to browse through our website
1992 Toyota Previa (Lucida) 60k 4X4 Turbo Diesel *SOLD*
- MardyDelica
- DSCN5607.JPG (75.38 KiB) Viewed 3991 times
- DSCN5609.JPG (87.09 KiB) Viewed 3988 times
- DSCN5621.JPG (80.12 KiB) Viewed 3989 times
- DSCN5618.JPG (92.01 KiB) Viewed 3988 times
- DSCN5640.JPG (68.6 KiB) Viewed 3987 times
- DSCN5635.JPG (74.72 KiB) Viewed 3983 times
- DSCN5639.JPG (79.31 KiB) Viewed 3983 times
- MardyDelica
Re: 1992 Toyota Previa (Lucida) 60k 4X4 Turbo Diesel (Arrived)
This Toyota Previa Diesel Arrived Now. in Rmd
if need to view this Previa.
Pls give me a call.
Amazing Auto imports Ltd
604-247-2111 / 604-720-6144
thanks,
Pls give me a call.
thanks,
samsplacci
this rig looks good Mardy. Too bad Amazing Auto wasn't closer to me in Mississauga. cheers.
- MardyDelica
Hi, Just recieved this nic elow mileage turbo diesel previa. no rust at all very nice. nothing to say on this van its a jewel with such a low mileage with 4x4 on it.
i can ship this previa out to ontario. no problem.
Cheers;
Cheers;
- MardyDelica
update, for this Previa diesel.
test drive this previa & it runs beautifully, runs like a gasoline previa same as out local previa but its a turbo diesel. 2.2 liter.
wow surprise w this previa lucida diesel runs. fast even its a AWD Van.
pls call me if you need info;
Totally runs good & no rust at all, inside is clean i mean mint condition despite of its a 16 yrs old Van.
Cheers;
Cheers;
- MardyDelica
Re: 1992 Toyota Previa (Lucida) 60k 4X4 Turbo Diesel *SOLD*
Hi, Update, Toyota Previa Diesel is SOLD.
Thank you
Thank you
