1993 Delica Super Exceed 184 kms. Arrived * Sold *
MardyDelica
Post by MardyDelica »
1993 Delica Super Exceed 184,000 kms. In-Transit (Green color; No Rust)
Amazing Auto Import Ltd;
DL # 30843
Mardy (Mardydelica)
Richmond, B.C.
T- 604-247-2111 / 604-720-6144
PLs see our feedback on this topic, Thanks:
http://www.delica.ca/forum/delica-deale ... -3086.html
Will do the ff. service & Details of this Delica:
1.) Will Change New Timing belt (Mitsubishi 2 Pcs), new Japan made water pump, new bearings, 4 new seals (Mitsubishi), New thermostat;
2.) Will change all fluids such as oil, gear oil, antifreeze;
3.) New transmission oil, change all filters, clean transmission pan;
4.) New depot headlights with 4 new osram bulbs (Made in Germany);
5.) Comply & register with day time running lights;
6.) 4 brand new tires;
7.) Undercarriage will be re-greased;
8.) 4 New pro-comp shocks 9000 series;
9.) 1 yr. or 12,000 kms warranty - which ever comes first (Power train);
10.) New anti-sway bar bushings upper & lower (Poly-urethane);
11.) Has a Middle 3 point seat belt good for your family & kids
12.) 7 passenger
13.) Clean car
14.) No rust anywhere as see in the pictures
15.) Runs very good & stable;
16.) We reseal the front panels on all our Delicas ,so you won't have to worry about floor leakage.
17.) will inspect rotors, pads or shoes and replace if needed & repack the front hubs & bearings.
MardyDelica
Re: 1993 Delica Super Exceed 184,000 kms. * SOLD *
Hi, this delica arrived, nice condition no rust under,
runs very good despite of the high mileage, looks like its just break in thru the engine. ready for veiwing.
Call me if you need to have a look for test drive,
cheers;
MardyDelica
Re: 1993 Delica Super Exceed 184 kms. Arrived * Sold *
Delica is SOLD
Thank you
