Just curious if anyone can describe the process of changing a headlight bulb..... It is just the one daytime running light bulb that is burnt out, but I'm not sure how to get at the bulbs themselves.
Thanks for any advice..
MAtthew
how many delica.ca members does it take to change a bulb?
Manitoba Delica
- Vehicle: Mitsubishi Delica P25W
Re: how many delica.ca members does it take to change a bulb?
if you look beside the side marker light there is a screw, undo it, then two more that are under the headlight (sort of in the crack between the headlight and the bumper)
this will allow you to pull the side marker light and the trim around the headlight straight forward and off.
you will now have access to the bolts that hold the headlights on, 2 under the headlights and 1 or 2 (can't remember) on the side of the unit.
after that you can remove the whole assembly, it takes some fiddling, but it does come out.
the bulbs are accessed through rotating hatches on the back of the assembly.
