For sale: 1993 Delica Exceed 141,000 kms. In-Transit, Arrived
Price: $10,400
Amazing Auto Imports Ltd
DL# 30843
Mardy( MardyDelica)
Rmd B.C.
604-247-2111/ 604-720-6144[/b]
Will do the ff. service & Details of this Delica:
1.) Will change New Timing belt (Mitsubishi 2 Pcs), new water pump Japan, 2 new bearing, 4 new seal (orig mits),thermostat. Timing belt change belt change at 123,000 kms in japan. but will check & replace
if needed.
2.) Will Change all fluid oil, gear oil, antifreeze
3.) New transmission oil,change filter, clean transmission pan;
4.) New depot headlight with 4 new osram bulb (Germany);
5.) Comply & registered with day time running lights; 6.) 4 brand new tires;7.) Undercarriage will be re-greased; 8.) 4 New pro-comp shock 9000 series; 9.) No rust 10.) Will put new anti-sway bar bushing upper & lower (Poly-urethane);
11.) 1 Battery 12.) Runs very good & stable
13.) 7 passenger seat model inside is very cl
14.) Will change all the brake pads & shoes if necessary;
15.) Very Rare Blue color Delica
16.) will do front panel seal, inner & outer to prevent front water leak
1993 Delica Exceed 141,000 kms In-Transit ( Blue color) SOLD
- MardyDelica
- DSCN6001.JPG (84.34 KiB) Viewed 5337 times
- DSCN6007.JPG (86.58 KiB) Viewed 5337 times
- DSCN6010.JPG (82.55 KiB) Viewed 5333 times
- DSCN6018.JPG (88.2 KiB) Viewed 5333 times
- DSCN6020.JPG (88.6 KiB) Viewed 5330 times
- DSCN6023.JPG (84.14 KiB) Viewed 5328 times
- DSCN6025.JPG (65.24 KiB) Viewed 5322 times
- MardyDelica
Re: 1993 Delica Exceed 141,000 kms In-Transit ( Blue color)
Hi, Delica arrived, very good condition inside & outside clean, no rust.
looks like grade 4 but only Grade 3.5 & B.
now ready for viewing,
Cheers;
Amazing Auto imports Ltd
Mardy ( MardyDelica)
Cheers;
swilliams
hi mardy it was great meeting you in person after all the positive feedback we've had. we look forward to owning a delica of our own!
cheers,
Shawna Williams
cheers,
Shawna Williams
- delicat
I saw this Delica today, it's unbelievably clean! The color combo is really nice as well but this thing doesn't even have a scratch and the interior looks unused! If you got this unit swilliams, will have something to brag about! I can understand why you'd like to pimp it a little...
Enjoy!
David
Enjoy!
David
- MardyDelica
Hi, thank you Shawna & david for the compliments.
On hold for Now. got the deposit, Thanks
no problem shawna will try my best to give you the good servcie that i give to any of my customer:
thanks again shawna:
Pls phone me anytime;
Amazing auto imports ltd
DL # 30843
Mardy ( Mardydelica)
DL # 30843
I bumped into Mardy yesterday, while he was getting this van inspected.
Holy cow, I don't think I've seen a Deli with better preserved paint job..
Good unit.
Good unit.
swilliams
yes the paint job is crazy other than the one black panel up front that has sun damage or something the paint is perfect and so is the interior. oh and i can't forget that the engine is getting the mardy treatment so basically we have a brand new 15 yr old van on our hands!!
yup she's a bute we bring the buffed beauty home on friday. then off to tofino next week for our first road trip.
we'll take some shots and if i can figure out how to put them on the website i'll post them for all to see.
shawna
shawna
- MardyDelica
Hi, Delica is sold to a nice couples.
thanks Again, Shawna & Roy, A pleasure doing business to both of you.
Cheers;
Mardy (Mardydelica)
Cheers;
Mardy (Mardydelica)
