Im sure some one has come across this before
http://www.dieselsecret.com/
Complete shit? i cant tell, doesnt make sence why people would be doing all these other expensive ways of changing there fuel if you could just add something to your veg oil to make it run regulary in your deisel engin.
check out this quote seems way to good. "No heating required at all! No conversions! No dangerous
methanol! Works in NEWER and OLDER diesel engines. Even those with power upgrades."
My opinion at least is that little youtube comercial in the corner of the page is fake, all those people talking are deffinatly readin a script, sounds SO fake.
anyways whats ever one else think on this?
So Whats This About?
- patty
- Vehicle: delica chamonix
- patty
Re: So Whats This About?
Also the UV filter they offer is the exact same product i bought from a pet store and use in my aquarium.
http://www.newenergyreport.org/019346.html
Whoever decides to buy that , should probably also invest in the "Fuel Optimiser" for even FURTHER fuel savings.
http://www.northerntool.com/webapp/wcs/ ... _200321455
Follow all that up with the "TornadoFuelSaver"
http://autocanada.272.com/272/autocanada/tfs.php
and you'll be driving at 99mpg in no time
- BCDelica
From - http://greasecar.com/forum_topicview.cf ... picID=3349
Basically the manual tells you to buy a Walmart plastic garbage can a couple of pumps and a couple of household water filters, hoses and fittings. Install a Goldenrod filter in one for water removal and wa-lah your system is ready. Actually you also add Kerosene (10% ratio), unleaded gasoline (5% ratio), some Diesel-Kleen+Cetane boost and the magical/miracle potion (DSE) and then pump in your tank. Its pink in color and smells somewhat like paint thinner.
I have a friend who is a lab rat and will take it in for analysis. Out of curiosity, I'm going to mix a small batch up and see how it does in the fridge and then the freezer. I'm still scared to put it in my 2000 Dodge Cummins. It also has a chart stating that it is good to 30 degrees. Add 5% more kerosene for every 10 degrees colder. Blow is the mixing ratio, you guys are the gurus out here. What's your opinion?
20gal filtered WVO, 2gal Kerosene, 1gal unleaded gas, 15oz Power Service+Centane boost additive, 3.5oz of DSE mix slowly for 5 minuets and put it in the tank.
Call me BCDelica-less
