Squeak when in 4WD
Squeak when in 4WD
When I am in 4WD (high or low) I hear a squeak from the left front wheel when driving at low speeds. Any thoughts on what might create such a squeak? Wheel Bearing?
bae146
Re: Squeak when in 4WD
Probably you cv joint is lacking lubrication. Check your cv boots, ensure they are not cracked or split. You can remove the clamp on the big end of the boot and look inside to see if the grease is dried up.......
Thanks - I will check it out when I get back home...
