BACKSPACING / OFFSET CALCULATOR :
http://www.bigcustomwheels.com/info_specs.jsp
It's funny, I've pointed many people to that backspacing info link.mararmeisto wrote:Delica's normally come equipped with 215/85R15s (although that is not readily evident from the door sticker). 235/75R15s are suitable replacements (only about a 1.2% difference in tire size).
And here is an excellent article on backspacing and the importance of getting it right: http://www.fourwheeler.com/techarticles ... index.html
Not right = rubbing and/or damage to steering assembly, wheel well, tire, etc.
Good person to check with, I think, would be Mystery Machine.
I'm in BBY too.delicat wrote:jfarsang,
Would it help if I stored your rims until you get your vans? That way you could fit and compare once you get them. I'm in Burnaby and would be happy to help you out, just let me know...
The info there for the 31/10.5/15 is exactly the same as the rims that I am running...jfarsang wrote:
I don't know anyone except for Josh who's running 31's on an auto and that has responded.torchard wrote:Maybe this has been exhausted elsewhere but any issues turning 31's i.e. fuel economy, acceleration?
--T
Yepjcolvin wrote:"The only upsides to going to 31" tires are -
Lower RPM on the highway
1" more clearance drivetrain/body from the ground"
Well, and also bigger tires just ride better over bumps/potholes etc, have less tendency to dig in in soft ground/sand, etc etc.
Jonathan Colvin
Hi Jesse,So the following rims work without flares :
15x7 / 2.75 or 3" BC
15x8 / 3.75 or 4 " BC
