Anyone ever find non Ceramic brake pads? I pulled the rotors yesterday and was shocked at how little wear there was on the pads compared to how damaged the rotors were. Perhaps they could have used a softer material for the pads such as granite :).
I am going to see if Lordco can come up with something else using the part number I found here. Perhaps I need to get some made up using the old blanks.
Bob in Kelowna
Front Brake Pads ?
Delicanadabc
- Vehicle: Super exceed 91
Re: Front Brake Pads ?
You can use any brake pad that fit the Mistu Montero 89-92.
They are ceramic and I am not sure if there are other material offered at Lordco co but I am sure they'll tell you.
Good luck!
Good luck!
Just got back from Lordco. Raybestos PGD349 is an organic pad. We'll see how that works. Sure don't like what the ceramic ones did to the rotors.
Now to go back for the seals!!!
Bob in Kleowna
Bob in Kleowna
Make sure you check whether or not they are for single or dual piston caliper's.Delicanadabc wrote:You can use any brake pad that fit the Mistu Montero 89-92.
Good luck!
Most 92 Pajero's came with dual piston, whereas mine came with single (identical to the Deli's).
Jesse
