I am looking for a part # for the front prop shaft U-joints. I am hoping to not have to take it out until I've got a new one to put in so if anyone knows the actual number it would be appreciated!
Andy
U joint replacement
asorensen
- TardisDeli
Re: U joint replacement
We got ours replaced at CVI in Richmond. "MardyDelica" will know the part number as he supplied it. Let me know if you need more info, best wishes for your delica. Christine.
- mdrive
we have the U joint for delica, i don't the part number as the I have is after market GMB brand and don't have the OEM part number..
coaxial
I ruined one of mine quite thoroughly and my nearby mechanic (crown tech auto north van) had a replacement. Recently I noticed it doesn't have a grease point though... does this indicate it is of lesser quality than one with a grease point? anyone know?
bae146
Probably a sealed spicer u joint. IF so excellent u-joint.coaxial wrote:I ruined one of mine quite thoroughly and my nearby mechanic (crown tech auto north van) had a replacement. Recently I noticed it doesn't have a grease point though... does this indicate it is of lesser quality than one with a grease point? anyone know?
- BadgeStar
- Vehicle: '93 Delica L300 'The Black Van'
I have deleted/edited this post as I misread the original question and this post did not relate to it!
Barry.
Barry.
- ccautos
- Vehicle: 92 Delica SE
I have added the Precision u-joint numbers to the Wiki for the front and rear drive shafts .
