U4GM: Best Ways to Earn Coins Fast in Arc Raiders
1fuhd
Vehicle: Lexus
Post by 1fuhd »
Arc Raiders drops players into a tense extraction shooter where coins make all the difference. The fastest way to build up cash isn't chasing every fight—it's about running low-risk looting missions, grabbing high-value loot, and getting out before trouble starts. New players often make the mistake of over-gearing for PvP or hunting rare objectives too early, but the best approach is starting small and focusing on what actually nets coins. Targeting dense loot areas like Stella Montis and selling everything you don't need can get you to five million coins in under 15 hours if you stick to a smart routine ARC Raiders Coins.
Start with a free or empty loadout to avoid losing gear upfront. Bring a basic gun, a couple of bandages, two shield rechargers, and a hatch key in your safe slot. Head into Stella Montis day raids, focusing on spots like the Assembly Workshop, Medical Research, or the Lobby for high-density containers such as lockers, cupboards, and breachables. Trinkets are the priority—they sell for the most and stack easily. Grab energy ammo, arc parts, and any purple or yellow loot that fits. Keep runs short, around five to six minutes, to maximize the number of raids you can complete each hour, and extract before other players show up or arcs swarm. Each run can net 30k to 50k coins without taking repair damage.
This "snowball" method works because you turn every raid into guaranteed profit. Track your bench upgrade needs through the in-game menu to avoid stockpiling unnecessary items, and vendor the rest immediately. Once you hit 300k to 500k coins, you can afford a cheap Mk3 looting setup with minimal mods to slightly increase yields—averaging around 40k per run—while still keeping risks low. Players report earning around 350k to 375k coins per hour this way, far faster than combat farming or selling crafted items.
Side objectives like Queen Harvester puzzles are a solid addition. In areas like Dam Battlegrounds, quick puzzle runs give access to premium breach containers with high-value loot, yielding up to 100k coins per hour. Electro Storm events are another low-stress option: stick to map edges like Spaceport during husk spawns for uncontested probes and loot, with potential runs between 60k and 100k coins. Rotating these activities prevents burnout while still steadily growing your coin stash.
Avoid common mistakes that eat into profits. Don't pour coins into unnecessary bench upgrades or fully decked PvP setups that can be lost on death. Upgraded weapons and attachments sell poorly compared to raw materials, so craft only what you need and sell the rest. Night raids in Hydroponic Dome or Rocket Assembly can yield big hauls, but they bring higher PvP and arc risks—save them until you've banked a couple million. Always check containers for hidden items and craft basic meds during raids to keep runs profitable even if a fight goes wrong.
Progression falls into clear phases. From zero to 500k coins, spam Stella Montis empties to build a gear buffer. From 500k to two million, mix in Queen Harvesters and Electro Storms while picking up weapons along the way. Once you're between two and five million, you can start adding 20% fun raids for variety while safe farming covers the bulk of your income cheap ARC Raiders Coins. Free loadouts work perfectly because deaths don't seriously cut progress, and focusing on trinkets ensures a consistent baseline even on off runs. Co-op helps too, splitting loot to double efficiency without adding risk.
Following this loop turns Arc Raiders' grind into a steady coin machine. Consistency beats rare, big-score plays, and by tracking vendor prices and adjusting as loot tables shift, you can fund high-level expeditions, stat upgrades, and dream loadouts in days instead of weeks, giving you a clear advantage over newer players.
