I regret letting this go on for so long - but that aside - what am I going to find under this rust if I start grinding. Am I opening a can of worms? I suspect it has to do with components related to the moonroof?
Any advice is appreciated, thanks!
Roof Rust
- negativentropy
- Vehicle: L400 - 1995
Roof Rust
- 20210515_122950.jpg (166.24 KiB) Viewed 3015 times
- 20210515_122905.jpg (161.05 KiB) Viewed 3015 times
- 20210515_122852.jpg (126.45 KiB) Viewed 3015 times
Re: Roof Rust
If it was an L300 I would suggest taking out the roof liner to see how much rust you really have. They rust from the inside out and if that is the case for your L400 your in for some major effort to get rid of the problem. Good luck - this is the first I've heard of anyone with this problem on an L400.
Larry
Larry
- negativentropy
Re: Roof Rust
Cool thanks - yeah Ill see if I cant get a better look at whats going on from the inside.
