Hi,
Anyone know the replacement size for the drain plug and washer?
							L300 Fuel Tank Drain Plug
- White Mule
- Vehicle: 1991 Delica L300
White Mule
						White Mule
- White Mule
The bolt is a M8 and the washer is a corroded aluminum M8 washer.
To replace: Cut a cork 8mm in diameter wedged up to 12mm. Cone shaped. Remove the bolt with a catch bucket below. Quickly seal hole with finger until the cork is ready to be inserted. Insert the cork and clean bolt. Wrap thread tape 3 times around the bolt. Replace the washer with a new M8 Teflon washer. Found on Amazon for $15 (80 pcs box). Reinstall in reverse.
I replaced the second tank at the same time.
White Mule
						White Mule
