MUT2 Scanner in the Vancouver area?
riverrio
- Vehicle: 1998 Delica L400 2.8L TD
I have a '98 diesel and my SRS airbag light won't turn off. This forum: http://www.delicaclub.com/viewtopic.php ... &p=169228 suggests I might be able to reset it with a Mut scanner. I called CVI, Rising Sun, Japanoid, and the Langley Mitsubishi dealer, with no luck. Does anyone know somebody in the Vancouver area with a mut2 scanner?
saltypeanuts
- Vehicle: L400 Series 2
I managed to clear an airbag code without a MUTII on my 2000! See this info from my previous post:
Posting for information. I triggered an SRS light messing around with the electrical system. Today I was able to connect to the SRS module and clear the code. My van is a 2000 Series II, Diesel. Wasn't able to connect to the OBD module, maybe a MUTII is still required for that.
The scantool is an Autel ML 619, $150 on Amazon. If anyone in the Calgary area needs their SRS or ABS codes checked or cleared, PM me and I'd be happy to help.
poochike
RJD auto in North Vancouver has a scanner that works on the ABS and probably the SRS codes also. They are currently chasing down and ABS issue for me and there scanner not only shows codes , it graphs the sensors and can tell when one drops out when it shouldn't. Mine is a series 2 L400 diesel, but it works on the V6 too.
Good luck
Good luck
