Hi Fellow Delica Peeps:
The rear left window (the one that opens and closes) has come off the hinges. The glass did not break or was damaged in any way.... however the two metal hinges that hold the window broke. I am located in Whistler BC and would like to know if any of you knows of a shop that will fix this issue. thank you in advance
Rear Window repair
Blue Tuna
- Vehicle: delica 2800
Khrolar
- Member's Photo Album: http://www.delica.ca/Photos/VD
- Vehicle: 1994 L400, LWB, Super Exceed
Rear Window repair
Did the hinges themselves break? Or are the bolts just stripped? From what I found the hinges themselves looked like they might be bonded to the glass, but it's hard to tell without pulling one of mine apart.
