L300 - intermediate steering shaft ?
ypelex
Vehicle: delica L300 93
Post by ypelex »
Hi folks,
Need some help here. My steering became really stiff, it has been diagnosed to the part on the picture. You can see it underneath ( connects steering gear and steering rack), goes horizontally from front to back. Is this the intermediate steering shaft ?
Yaroslav
Sounds like you need the Steering section of the workshop manual: http://www.delica.ca/forum/viewtopic.php?f=115&t=7334
...but yes, the manual identifies that as the intermediate shaft.
ypelex
Post by ypelex »
Thank you for the link, Growlerbearnz.
Checked it out and as expected there is nothing to service in the shaft. Needs replacement. Stiff steering section doesn't identify it as a potential problem, but the mechanic says it is after doing a number of tests. I guess the part is exposed to rain/splash and over time bearing goes.
Maybe. If the bearings in the universal joint seized up the steering would get a bit stiff, but I wouldn't expect it to be *that* bad as the joint isn't on much of an angle. Still, it's not something I have first-hand experience of, so who knows.
You've checked your power steering fluid level, right? It's the first thing a mechanic would check, but if it is that it's a really cheap fix :-).
ypelex
Post by ypelex »
Yes, the fluid I checked - it is all good.
I agree with your assessment, not a lot of movement in that shaft, but it is now noticeably different comparing to normal. Will post here result once I find the part .
Part number MB412520, CAD$118 from Amayama.com.
...which seems surprisingly inexpensive.
ypelex
Post by ypelex »
Thank you again. Your posts on this forum are appreciated by many.
ypelex
Post by ypelex »
To confirm here : replaced the part & that fixed the problem. One of the U-joints was fully seized up.
Great! Thanks for letting us know :-)
