Mine was broken, so I had the tire carrier strapped up to the body somewhere.  Found a bolt at Canadian tire and crudely welded a nut onto it (tried not to breathe toxic smoke).  Used threaded rod for the bolt part.
I still have it strapped up as a fail safe. Does anyone see anything wrong with this?
[img]https://uploads.tapatalk-cdn.com/201804 ... 911e1e.jpg[/img][img]https://uploads.tapatalk-cdn.com/201804 ... 70bcad.jpg[/img][img]https://uploads.tapatalk-cdn.com/201804 ... e5d74c.jpg[/img]
Sent from my ONEPLUS A5010 using Tapatalk
						Spare Tire Lowering Bolt
				takeuchi
- Vehicle: 1992 Starwagon Super Exceed
The theory's good, but I don't trust that weld. It looks like the vaporising zinc plating has interfered with the arc. I'd grind it back a little, grinding off the plating where you're welding, and have another go with the welder turned up a bit to get better penetration.
				Jumboshrimp
- Vehicle: Mitsubishi Delica
				takeuchi
Anyone know the size of the bolt and the thread pitch?
				204explorer
- Vehicle: l400
CCA has them for sale. Thought i let you know.
Sent from my SM-G950W using Tapatalk
				takeuchi
I bought the hook but forgot to buy the bolt. Thought it would just be cheaper to pick one up at hardware store if someone knows the bolt size and thread pitch.204explorer wrote:CCA has them for sale. Thought i let you know.
- north54
- Vehicle: 1989 P35W
That would be my guess as well, but I don't actually have one to measure. It's also a slightly unusual thread pitch- most M12s at the hardware store will be M12X1north54 wrote:Pretty sure m12x1.25
