So I went out the other day to let the van warm up a bit while I got my jacket and shoes on, and it didn't start. Not the end of the world, I took the car.
Later, I was troubleshooting with my wife and discovered that she had filled the van and not put in any fuel conditioner. I figured the diesel might be gelling, so I added some conditioner, let it sit for a few hours and it started up like a dream that evening!! Problem solved, and I'm a genius!!!
That was two days ago and it hasn't started since. And it hasn't been that cold. It's around 0 today. So methinks it's not the fuel conditioner...
When I turn the key, it cranks, but it never catches. I thought the batteries might be dying/dead, but I checked those and they both measure 12.53v, which is a little low, but is that enough to keep it from starting? Any idea what to test next/how to do it?
						Starting Issue (not due to the cold?!?!)
				pj_jazzy_janz
- Vehicle: '94 L400 LWB
				204explorer
- Vehicle: l400
Are your glow plugs working? Any smoke? Maybe pump the primer until it builds pressure.
Unless there is something really wrong with the fuel it won't gel. No additive needed.
Sent from my SM-G950W using Tapatalk
				pj_jazzy_janz
Sent it to a shop. Just don't have the time to putter around these days (and no garage means it's chilly work!!).
Thanks for the help! I can't stress enough what a fantastic resource this site is!!
				pj_jazzy_janz
Turns out it's having its fuel pump rebuilt. So, I'm rather glad I didn't spend too much time fiddling around, as I'd not have been able to tackle that!!
				Ralph in Winnipeg
- Vehicle: 94 Strada
Not great news but at least you know what's wrong.  Who is doing the rebuild for you?
Ralph in Winnipeg
						Ralph in Winnipeg
				pj_jazzy_janz
Well, after 8 weeks (no fun with 4 kids and a Corolla) at a diesel shop that ended up not fixing the problem (but did still manage to cost us an insane amount of money) I took it to Peg City Auto. He tinkered with the fuel pump as well, and had it running, but he still wasn't satisfied with it, so he dug a little deeper. Turns out it was the harmonic balancer - it was off by about 90 degrees. He replaced it, and it's been running like new ever since!!
				poochike
That's great news it's fixed, but keep an eye/ear on that harmonic balancer. If you hear a squeal that sounds like a belt when you start it up cold, but belts are tight your balancer could be slipping. A failed balancer can cause some pretty major damage. If it was running great and then all of a sudden not starting and it was because of the HB, I would probably change it out. Good luckpj_jazzy_janz wrote:Well, after 8 weeks (no fun with 4 kids and a Corolla) at a diesel shop that ended up not fixing the problem (but did still manage to cost us an insane amount of money) I took it to Peg City Auto. He tinkered with the fuel pump as well, and had it running, but he still wasn't satisfied with it, so he dug a little deeper. Turns out it was the harmonic balancer - it was off by about 90 degrees. He replaced it, and it's been running like new ever since!!
