AU NOUVEAU-BRUNSWICK CANADA! NEW-BRUNSWICK CANADA
				Delica_Acadie
- Vehicle: Mitsubishi Delica Exceed L400
Hi there, I have a mitsubishi delica L400 of PE8W series.  Got some little issues that I wish to fix. Anyone know a good source for manuals?
						- Lapprentis
- Vehicle: Delica L300 StarWagon 1990
Salut l'Ami de l'Acadie :) It is about the same here in Québec as in NB   First, stay tune here and trt to get as much info as you can as for finding what it the problem and what parts number you may need. Then, second step: Just find someone that have some exerience in Diesel (self worker or small town garage; there are a lot in NB.) and it should be OK. Where are you located ?
Lapprentis
  First, stay tune here and trt to get as much info as you can as for finding what it the problem and what parts number you may need. Then, second step: Just find someone that have some exerience in Diesel (self worker or small town garage; there are a lot in NB.) and it should be OK. Where are you located ?Lapprentis
				Delica_Acadie
Salut l'ami du Québec! Tu es peut être Acadien   . Je suis dans la péninsule Acadienne. Merci de ta réplique. J'ai fait un post dans l400 sur une problème avec probablement un ajustement de la fuel injection pump.  Recherche en cours!
Translation : Hello friend from Quebec! You may be Acadian too! I am in the Acadian peninsula with is north east of NB. Thanks for your reply. I did a post un l400 technical about an issue on what may be the adjustment of the fuel injection pump. Research on the go!
  . Je suis dans la péninsule Acadienne. Merci de ta réplique. J'ai fait un post dans l400 sur une problème avec probablement un ajustement de la fuel injection pump.  Recherche en cours!Translation : Hello friend from Quebec! You may be Acadian too! I am in the Acadian peninsula with is north east of NB. Thanks for your reply. I did a post un l400 technical about an issue on what may be the adjustment of the fuel injection pump. Research on the go!
				gillbates
- Vehicle: 2002 L400 V6
Hi Delica_Acadie,
I found this while poking around on the site
http://www.delica.ca/manuals/
hope this helps
hope this helps
