Headlight light bulbs
bassnailer
Do you folks also find yourselves changing light bulbs in your headlights every four to five months? I keep a stash of H3's in my cold box. Am I the only one?
Nope. My current bulbs are 7 years old, the previous ones were factory fitted.
Are you fitting the correct 55W bulbs? Higher wattage bulbs can overheat and fail.
Check your wiring to the headlamps too, especially the earth connection. An intermittent connection can cause the filaments to fail earlier than they should.
bassnailer
Honestly, I don't know if they are 55 or not. They are from Canadian tire, Certified brand H3 bulbs. They don't mention anything regarding watts. I'll have to check the wiring as well. I know that there are a few too many things connected to my battery. Not sure what they do. Wonder if that might have something to do with it.
- righthandman
- Vehicle: L300
Where's a good place to buy new bulbs? Looking to replace a dead one on my 91 L300. Are they easy to replace yourself?
Thanks!
Peter
Thanks!
Peter
Stella87
- Vehicle: Mitsubishi Delica L300 P35W
When you replace them is the ground wire look okay? If the bulbs are cheap a bad ground could burn them out quick. L300s headlamp ground wire is a common problem. A lot of people end up soldering a new ground wire to the headlamp and fitting the other end with a better connector to the new bulb to solve the problem
Sent from my SM-A520F using Tapatalk
"Delilah" 91 L300 P35W Exceed
Stella87
I bought the Philips Crystal Vision Ultra on Amazon they weren't cheap but they're a lot brighter. I'm just having an issue with aiming my headlights nowrighthandman wrote:Where's a good place to buy new bulbs? Looking to replace a dead one on my 91 L300. Are they easy to replace yourself?
Thanks!
Peter
whiteheadjesse
- Vehicle: 1992 L300
Did you ever figure out how to aim your lights?
Which bulbs did you replace with?
Sent from my Pixel using Tapatalk
whiteheadjesse
Oops, just saw the same of the bulbs now...whiteheadjesse wrote:Did you ever figure out how to aim your lights?
The Philips Crystal Vision are great, despite the stupid blue tint band. Osram Nightbreakers are also excellent.
TieMyShoe
- Vehicle: L300
Used to replace a bulb every oil change... got annoying. Installed LEDs and have not had an issue since.
- Lapprentis
- Vehicle: Delica L300 StarWagon 1990
Does the Wattage need to be consider for LED replacement ? Is a LED 100W producing more bad heat than an original 55W ?
Lapprentis
Lapprentis
TieMyShoe
- Vehicle: L300
mine stay cool to the touch
demiro
- Vehicle: Delica
I'm very pleased with the brightness of Osram Nightbreakers.
Furi
- Vehicle: 1990 L300
Which LED bulbs did you use? Any issues since? Installation any different?TieMyShoe wrote:Used to replace a bulb every oil change... got annoying. Installed LEDs and have not had an issue since.
TieMyShoe
- Vehicle: L300
some random brand with flexible heat sinks. I did not want to cut the backing. They have been great so far.
